Home > Technical (L322) > Whats behind an MY11 bumper!
p-trax
Japan 2011 Range Rover Vogue 4.4 V8 Santorini Black
I removed the bumper cover today, in preparation to install tow bar armature.
the yellow area shows one of the fixing points for westfalia armatures.
in the close up picture below you can see two welds highlighted. There are two identical ones below, and the same on the left hand side.
according to the instructions, and the chief service technician at my dealers, these should be bolts (that are removed to enable fitting on armature).
Anyone here had a towbar fitted after delivery of vehicle (ie not factory fit)?
I am taking the car to the dealer tomorrow morning, but as far as they are concerned (via telephone) this is not correct.
Any words of wisdom gents? Gerry
____________________________________________
Arrived>Santorini/Jet FFRR MY11 TDV8
Gone>Stornaway/Ebony MY09 RRS HST TDV8
Gone>Java black/Ebony MY07 RRS HSE TDV6
Post #65047 20th May 2011 3:49pm
p-trax
Am I just being Dim, is there more to remove?
the actual metal bumper does not seem to have any visible fixings. Gerry
Post #65050 20th May 2011 3:57pm
My only comment would be that you're very brave dismantling a lovely new car! Discovery 4 HSE
Post #65051 20th May 2011 4:01pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
there are bolt on the inside which you have to take of as well the whole metal bumper has to come off
Post #65056 20th May 2011 4:10pm
p-trax
I am not sure i have ever purchased or received anything vaguely mechanical in my entire life that i have not dismantled/modified etc .
one of my earliest memories is getting a scalextrix type racing set for xmas, and stripping down the cars and motors (removing the magnets, brushes and coils) to see how it worked.
I got in serious trouble, and after reassembling and proving all was OK, I received a further scolding for being cocky Wink Gerry
Post #65060 20th May 2011 4:18pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Just done this on my 2010MY and as Havank states the bolts are on the INSIDE Exclamation
Removing the outer plaster bumper skin will not help Shocked You need to take out the removable floor of the boot that houses the spare wheel, remove both smaller side sections and also the black plastic panels below them Rolling Eyes
This will then allow you to access the 8 nuts which when removed will allow complete removal of the bumper Thumbs Up
Should I be posting a write up on this Whistle 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #65061 20th May 2011 4:19pm
p-trax
Ajay, that's great.
back off out side then Smile Gerry
Post #65067 20th May 2011 4:36pm
Havank
I was looking if i could find my full write up on how to fit the towbar on rangerover.net, but its gone
it took me about 3 hours to fit the car
I had to take the car to LR to have the ecu reprogrammed so it would recognize the towbar
Post #65069 20th May 2011 4:39pm
Ajay(UK)
Still yet to do that but the electrics work perfectly just have to manually turn off the rear parking sensors when hitched up and reversing Rolling Eyes
I think 3 hours in total is a fair assessment too - but be aware of the 21mm bolts underneath Exclamation I needed an air gun to undo them Shocked
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
Post #65071 20th May 2011 4:44pm
Ajay(UK)
My completed Westfalia Tow Bar retrofit for the record Thumbs Up
I wish I had taken more pictures now during the installation Embarassed
Post #65076 20th May 2011 4:54pm
Havank
I did (when i did it back in 2006)
but i noticed that the full write up has gone, as well as my pictures on imageshack
maybe that is why it is gone from rangerover.net. as the pictures weren't showing anymore
Post #65085 20th May 2011 5:39pm
nbunney
Have a look on here to find the fitting instructions:
http://www.ownerinfo.landrover.com/extfree2viewlrprod/index.jsp
Post #65097 20th May 2011 6:02pm
p-trax
That was a more "FULL ON" excercise than originally expected.
Thanks for the help BTW, I was seriously misslead by the instructions that came with the armature itself.
It appeared as though the 8 bolts were external, not internal.
ANy how, i feel much more intimately aquainted with my vehicel now Laughing
Bit of an "interesting" job for one person, would not have managed without the ratchet stands.
Almost complete strip out of boot, including disconnection of LHS electrics.
Ended up making a last minute trip to Halfrauds to get long collared socket set to access the interior bumper fixing bolts.
On my travels I came across a couple of mysteries (to me anyway) ;
whats the green metal tank beneath the spare wheel?
whats the electric cable that terminates behind the rear mudflaps (last picture below)?
 Gerry
Post #65200 21st May 2011 10:14pm
nbunney
Gerry
The tank is for the air suspension
Post #65202 21st May 2011 10:46pm
p-trax
nbunney wrote:
Gerry
one down.............one to go (thanks BTW) Gerry
Post #65205 21st May 2011 10:58pm
