Home > Technical (L322) > Wing mirror bulbs/LEDs
I've been slowly changing my interior bulbs to LEDs and only have my wing mirrors left to do. Which ones do i need and what is the max diameter that can fit in?
Has to be said the look of the interior if far better but some wont like it but each to their own.
Post #59602 9th Apr 2011 10:00pm
daveo
you need T10's same as the side light fitting, no error code to worry about, but use forward facing led's max dia 11.5mm you could get away with 12mm but better to be safe then sorry
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #59606 9th Apr 2011 11:12pm
Cheers Daveo. I guess the pics of the LEDs are your ones? What the hells the knurled brass bit? I've got a few of that fitment left over so will have to give them a measure. Do the ones you have only have one LED?
Post #59613 10th Apr 2011 7:10am
daveo
hi yes its a single smd and i dont have a clue what the brass bit is like that but they came in under 12mm, my mate used the same type but it had 4 glass led's facing forward and i think they may be that bit brighter V8 facelift Range Rover Autobiography 22" wheels.
Post #59624 10th Apr 2011 9:45am
Got the LED's but how do i get to them? cant find them in rave.
Post #60411 14th Apr 2011 10:55pm
