Home > Range Rover Classic > Chevrolet LS 5.3 or LT 5.7 engine swap for RR Classic |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 |
Can’t help with any of the technical details but a company in the UK called Overfinch used to make custom Range Rovers using Chevy V8 engines. It might be worth looking for an Overfinch Range Rover to buy, or if you’re determined to make your own, then maybe an Overfinch forum could be a useful source of info. Good luck with your project 2006MY 4.2 SC
5th Apr 2020 4:17pm |
flashgordon Member Since: 23 Sep 2019 Location: Hannover Posts: 76 |
Yes, I know. And I received an answer from Overfinch today (Sunday!!!).
5th Apr 2020 9:51pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2557 |
There are reasonably straightforward routes for an LS swap nowadays - easiest way is to buy a pull-out with engine/gearbox/ECU/accelerator pedal etc from the donor. Contact these people: https://rw-eng.com |
5th Apr 2020 10:12pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
Not sure if you've seen this, if not you may find it interesting -
6th Apr 2020 8:47am |
LT Member Since: 13 Mar 2017 Location: South West Posts: 395 |
I’ve owned two LS1 5.7 powered HSV Clubsports. The VT and VX based models.
6th Apr 2020 10:51am |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Bolting that amount of hp and torque to a RR tranny will result in tears unless you have a very light right foot or don't use the power (what's the point in that??). So use a US tranny and find an adaptor for an LT230 which is probably the most robust LR T-case.
6th Apr 2020 1:00pm |
As above, there’s a solution to use a Gen IV/6L80 (or Gen V/8L90) with an LT230 that keeps everything in its original position. |
8th Apr 2020 11:30am |
I now finally located an original Schuler Voith Transfer Case from early 80ies combined with a TH350 transmission.
8th Apr 2020 11:52am |
Thanks Trommel for the additional PM Information
8th Apr 2020 1:27pm |
