Home > Technical (L322) > [Mechanical] Handbrake adjustment- How To
Here is the excerpt from the L322 Workshop Manual
Adjust
1. Raise rear of vehicle.
WARNING: Do not work on or under a
vehicle supported only by a jack. Always
support the vehicle on safety stands.
2. Remove rear road wheels.
3. On each rear brake:
4. Remove adjuster access plug from brake disc.
5. Rotate brake disc until access hole is in the 6
o'clock position.
6. Using a screwdriver or similar tool, turn brake
shoe adjuster until resistance is felt. Apply
handbrake several times to centre shoes, re-adjust
if required and repeat.
7. Ensure handbrake is released and check disc
will not rotate.
8. Back the adjuster off 8 notches, check disc is
free to rotate.
9. Fit adjuster access plug.
10. Fit rear road wheels and tighten nuts to 140 Nm
(103 lbf.ft).
11. Handbrake lever assembly is self adjusting and
will correctly tension cables. However after
adjustment apply handbrake several times,
release handbrake and ensure road wheels are
free to rotate.
12. Lower vehicle.
Post #3786 13th Mar 2009 1:20pm
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
Re: Here's the officla way to do this
This is great, thanks for posting.
I have followed this today without luck.
Can you advise which direction it should be turned?!
I turned mine both ways and it didnt stop the disc from turning..... L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #125453 9th Jun 2012 9:09am
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
I'm guessing there is something else wrong with mine - I have done this procedure exactly as stated with no luck, the handbrake is and always has been crap. The handbrake lever also seems to come up very high.
Do the inside of the handbrake glaze up over time reducing their performance? Thinking I may have to pull mine apart for a closer look.
Any ideas would be greatly appreciated.
Cheers - Gav
Post #125557 10th Jun 2012 9:54am
No they weren't glazed up on mine when I took the discs off to replace them. Lots of dust and muck inside though. The "cog" seems to catch on the lower spring preventing it from turning.
When you take it all apart (disc off etc) the cog turning should make the adjuster screw out, thus reducing the gap between shoe and disc. .
Post #125559 10th Jun 2012 10:03am
@ The Brains Trust
Yes the brake drum and shoes glaze up. Thumbs Up
My handbrake was next to useless.
Took the drums off and found the drum and shoe surfaces had a hard layer of glazed dirt on them.
Emery papered the drum surfaces back to as new, same with the shoe surfaces.
Checked that the adjusters were free and lightly lubricated and put the whole lot back together after roughly adjusting the shoes.
Finely adjusted the shoes and now the handbrake is really effective.
Well worth the effort.
This on a car that had a full Main Dealer Service History.
Post #125562 10th Jun 2012 10:23am
The Brains Trust
Thanks for that - mine has a full dealer service history too - mustn't be part of their checks...
I'll whip the brakes apart when I get a chance - just started an engine upgrade on my Classic Rangie, so it won't be for a few weeks at least...
Post #125652 11th Jun 2012 10:19am
mzplcg
If you want a comprehensive manual on these braking systems go over to Disco3 and search for "Bodsy's Brake Bible".
Very D3 orientated but these things are so similar that it doesn't matter. The thing is well worth downloading and printing off.
Post #125706 11th Jun 2012 5:58pm
mjdronfield
Mine needs taking up a bit. Which way do you have to move the cog ? Push it upwards till it stops ?
Can you do this 1 wheel at a time ? - I'm guessing not.
Don't have 2 jacks or axle stands.........
Mmmmm 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #206962 31st Aug 2013 9:22am
When I did mine I had both wheels off the ground.
To adjust, one cog has to turn clockwise and one has to turn anti-clockwise.
Unfortunately I can't remember which is which. Smile
Post #206965 31st Aug 2013 9:48am
mjdronfield
Cheers.
Thinking about it, I suppose if it stops turning and the wheel still moves, you have to turn all the way bck the other way.
Seen what may be a nice set of 3 ton axle stands on the bay for less than £20 delivered.
May be worth a punt......
http://www.ebay.co.uk/itm/2-x-3Ton-Warrior...27d3c9fc57
Its not like I can't wait a week for the stands if needs be.........
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #206967 31st Aug 2013 9:56am
mjdronfield
OK...Obtained axle stands earlier this week and have attempted, and aborted, adjusting the handbrake.
First off, where are you supposed to support the RR with axle stands ? The instructions with the stands say the car needs to sit "in the cup". There is nowhere that I can see to have them support it properly ;
I wasn't totally happy getting the other side up and resting it all on the 2 points of the stands.
I was also unable to see down the hole for the cog.
Decided would best be done by the garage with the proper kit.
So where is the best point to support the car ?
Thanks. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #208699 7th Sep 2013 12:30pm
Do you know of anyone with a set of orange Axle Stand for sale by chance? Whistle
Post #208705 7th Sep 2013 2:11pm
mjdronfield
Rolling with laughter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #208709 7th Sep 2013 2:22pm
I tend to use the trolley jack with a flat wood block under the point where your stand is, when car is on the ground this is nice and "level". This allows to get the car to a height to get the axle stand under the jacking point for support.
RAVE indicates to use the front inner bush mount of the lower arm to provide support, but as the weight of the axle changes the angle, this can be a bit of a fiddle.
Post #208716 7th Sep 2013 2:46pm
mjdronfield
Ah. OK. Makes sense. Many thanks.
Have managed to use ramps until this point, but having the wheel off, obviously I can't.
I'm pretty sure the cup on my axle stands is not wide enough to follow the RAVE illustration.
Will have a look when I'm in the garage next.
Thanks again.
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #208718 7th Sep 2013 3:24pm
