Home > Maintenance & Mods (L322) > Water from Expansion Tank....
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Hi,
Last couple of weeks I noticed a small pool of water under front passenger wheel coming from the expansion tank above of my 2003/53 V8 Vogue (BMW 4.4). Tank and Cap changed but still coming out. Last night I dried all the coolant off from around the tank and left it over night....this morning there's coolant around the tank again by the cap and the plug. How? Car not started ......any ideas anyone?
I've had a looked around and suggestions range from Head Gasket to Thermostat. Radiator was changed last year with all fresh coolant too so no issue with blockages and fins look fine.
cheers
Post #54149 11th Mar 2011 7:37pm
Split expansion tank ? Quite Commone and tends to only leak when under presure . 2008 MY Supercharged
Post #54150 11th Mar 2011 8:39pm
Superspoons
Axle - yes, expansion tank and cap replaced for a Britpart one yesterday. Should I of gone Genuine Parts.... ?? Also,looked through paperwork and thermostat changed in July. It's booked in to my local independant on Monday....
Post #54152 11th Mar 2011 8:53pm
Superspoons
Well it's back...and nothing found Sad
Pressure Test - OK.
Thermostat - OK.
No fault codes recorded.
Bit miffed though as despite saying they had'nt found any leak there was water still on the floor and around the cap of the header tank.
So, when I got home I took a look again and wrapped PTFE around the two threads on the top of the tank (Main cap and smaller, 'grub' screw).
Went for a 10 mile run at motorway speeds and no leaks at all. Let it rest for 20 minutes, no leaks... Have I fixed it...only tomorrow morning will tell if there is a patch of coolant under the front... Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #54723 14th Mar 2011 11:07pm
daveo
hi, so are you saying it was coming from the thread on the tank that the cap screws down on... V8 facelift Range Rover Autobiography 22" wheels.
Post #54738 14th Mar 2011 11:53pm
Superspoons
Daveo,
Exactly mate. The tank and cap are brand new too Shocked
If it turns out this is the case I'll invest in new genuine LR items and not the Britpart ones I've got - probably all from the same production line though. Perhaps I've just been unlucky with a 'friday afternoon' cap/tank... Laughing Gavin
Post #54748 15th Mar 2011 6:39am
daveo
its funny as i loose a very small amount of water, may be a litre over 1000 miles but cant find where it goes..and that started after fitting a new header tank. i bought a tank from the dealers £48.00 V8 facelift Range Rover Autobiography 22" wheels.
Post #54756 15th Mar 2011 9:33am
dave, i had that on a fiesta years ago, turned out to be a high pressure fine spray of water which only showed after a long'ish journey... ... - .- -.
Post #54759 15th Mar 2011 9:49am
Superspoons
Ok - might have the reason for all this Very Happy
Garage rang me this morning and noticed that the cap on another 2003 V8 had 160 (I think) stamped on the top - not 140 that I have on mine. The 140 one is for a Diesel TD6 not the V8 4.4 apparently.
Could someone on here who has a 4.4 and someone who has a TD6 take a look at there caps and tell me whats stamped on the top please.....??? Gavin
Post #54799 15th Mar 2011 1:37pm
mines a diesel and i have 140 stamped on mine.. ... - .- -.
Post #54818 15th Mar 2011 2:20pm
Superspoons
Cheers stan...
Can anyone tell me whats on their 4.4 BMW engine...? Gavin
Post #54825 15th Mar 2011 2:41pm
p38arover
Australia
My 4.4 M62 BMW had a 200kPa cap, it now has a 140.
My tank was split as seen just at the transition from horizontal to vertical on the side - see pics. I replaced the tank today.
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #385014 3rd May 2016 9:58am
