![]() | Home > Technical (L322) > battery disconnected a few weeks - no crank no start |
annette Member Since: 07 Nov 2018 Location: Tilarán Posts: 30 ![]() ![]() |
A 4.4 NAS L322 came in some 5 weeks ago for oil leaks, bushes and some aircon problems.
Thank you for the answer.
Thank you for your fast reply.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Do you have a P showing on your dash saying you are in park ?
As I said above yes all gears appear on the dash!
The transfer box motor is a common fail but I don’t know if it would prevent cranking, you can calibrate the transfer box motor easily but can’t remember how but a google will tell you.
Sorry, but in the early ones, there is no calibration. You are probably thinking of a later model or an RRSport.
sounds like you know more about it than me so I am not much help to you.
thank you i knew this as an unjam trick for those who never use their transfer.. learned something today.
