![]() | Home > Maintenance & Mods (L322) > Lower arm replacement |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
So my upper arm ball joints and lower arms turned up today..
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
thank you Mark, put in the wiki.. |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Good one |
For info
Bazzer79 Member Since: 26 Apr 2016 Location: Thames Ditton, Surrey Posts: 43 ![]() ![]() ![]() |
I did this job at the weekend, but I followed another how to guide on you tube. The guide video didn't have the step of measuring the hub to underside of wheelarch and setting the suspension at the height again before tightening the bolt fixing the suspension arm to the subframe.
It is important, otherwise the inner bush will be under unnecessary stress "at rest" and at play !
Super important to either torque up on a 4 post lift or set the hub in the right position with a jack. As Joe90 says the bush will be twisted when the car is on the ground if you torqued it with the hub hanging at the end of the suspension travel. There is nothing that can't be fixed with a hammer😜😜
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
I've just done the Compression links. And there are several extra, annoying things that need to be known about to make the job easy (or very hard if you are not prepared).
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 528 ![]() ![]() ![]() |
I did my front lower arms today and |
I neglected to say a big thank you to northernmonkeyjones for the original howto which was extremely helpful. 2016 Skoda Octavia VRS Estate
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
duplicate post Cheers, Greg
So I got this ball joint tool as linked I think earlier up in this thread but reading your warning bgennette I'm concerned about damaging the rubber boot.
MikeO - Or were you changing the ball joint cassette so didn't matter if you damaged the boot?
I wasn't concerned about the boot. I trashed it. I also had a similar Toolzone separator but it didn't fit. Probably a smaller size than the one on your picture. I can't imagine it would have been up to the job of the one on the drivers side. It took so much force with the separator I had and a sledge hammer to get it out... 2016 Skoda Octavia VRS Estate
