Home > Technical (L322) > Egr delete...
Page 1 of 7 1234567>
ptaroni
Egr delete...
I have blanked the egr valves off on my tdv8 and im wondering wether they need to be turned off in the ecu, from what ive read they do else blanking them off will throw the eml however i have done over 800 miles since blanking with no issues, has anybody else had this or has it been mapped out already? Live data shows them working - commanded/actual so i cant see it being mapped out...... thanks 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #488210 6th Sep 2018 10:32pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I was under the impression they needed to be mapped out or emulated to avoid the EML. I assume you must still have them electrically connected and they were working before you blanked them?
Maybe it depends on the MY? Your profile is still showing a TD6. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #488211 6th Sep 2018 10:41pm
http://www.fullfatrr.com/forum/topic48517....24fbee5e2a .
Post #488212 6th Sep 2018 10:42pm
ptaroni
Hi yes they are still connected and were working fine before blanking. After reading so many egr horror stories thought i would blank them and then get it remapped but there is no need at the minute. All of the posts relating to egr deletes all have had remapping done!
I have also just updated my profile Thumbs Up 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #488214 6th Sep 2018 10:51pm
MikeO
Out of interest, where did you get the blanking kit (is it the ebay one?) and could you write up a few notes? I'd like to get around to blanking mine... 2016 Skoda Octavia VRS Estate
Post #488216 6th Sep 2018 10:54pm
ptaroni
Hi yes was an ebay delete kit. Take the engine cover off and you can see the short 90 degree bent egr pipes, remove the pipes and fit the supplied blanks. You need to use the supplied bolts as the original bolts are longer and bottom out in the hole without tightening the plates down. I replaced mine when replacing the thermostat housing but im pretty sure it would only take 15mins as all the bolts look pretty accessible. May need a magnetic pickup tool incase you drop a bolt! I wish i took some more photos when i carried out most of the work ive carried out! 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #488220 6th Sep 2018 11:09pm
MikeO
Thanks. I was put off because in the ebay description they talk about having to disconnect looms and move them out of the way and say its not a straightforward job on the TDV8. I also had a look at the EGR replacement howto on here which seemed very involved and so I decided I'd put it off for a bit! 2016 Skoda Octavia VRS Estate
Post #488222 6th Sep 2018 11:19pm
rar110
Do you have an eBay link? ______________________________
Post #488226 7th Sep 2018 6:33am
ptaroni
https://rover.ebay.com/rover/0/0/0?mpre=ht...2642302772 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #488228 7th Sep 2018 6:45am
rar110
Thanks. ______________________________
Post #488331 7th Sep 2018 8:49pm
kgeddes
@ptaroni,
Is it really as ‘simple’ as the eBay ad. photos suggest? Thanks
Post #488674 11th Sep 2018 2:29pm
ptaroni
Yes! Still no eml either and have done well over 1k miles since fitting! 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #488864 14th Sep 2018 7:03am
kgeddes
Thank you, glad it’s going well for you Thumbs Up
Post #488871 14th Sep 2018 9:48am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
a lot of vehicles don't require a delete / remap for blanked EGR's , transit vans for instance , so im not surprised your issue free pal but I still think your missing out by not having a remap Twisted Evil Razz
Post #488883 14th Sep 2018 2:44pm
ptaroni
I will have it remapped eventually, once ive sorted all the niggles out it will be next! 2004 td6 l322 - gone
Now 2007 tdv8 l322
Post #488917 14th Sep 2018 9:12pm
