Home > Wheels & Tyres > General Grabber AT3 255 55 R20
Page 1 of 8 12345678>
RiDDO
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Fuji White
Folks,
I have recently fitted General Grabber AT3's to my 2012 4.4 TDV8. I am running the pressures as per the manufacturers sticker at 33psi front and 36psi rear. My intention is to vary the pressures and see what effect it has regarding ride/handling etc until I find a setting that suits.
I've searched the forum but not found any posts relating to the same topic. If anyone has this tyre fitted please drop me a reply with the pressures you're running please.
--RiDDO --RiDDO
Post #484905 1st Aug 2018 3:09pm
verydisco
Interested in the same matter, same tyres but for an L405. Thumbs Up (RiDDO's being a L322)
Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #484923 1st Aug 2018 5:02pm
RiDDO
Have covered about 400 miles or so since the tyres were fitted. My speedo is more accurate than it was before! With 255 50's its was always 2mph faster then my GPS indicated (30=32mph), I trust my GPS more! The ride is definitely better. I have not adjusted the pressures yet 33psi front & 36psi rear. Will update again in a week or two.
--Ian --RiDDO
Post #485342 6th Aug 2018 8:18pm
verydisco
Thank you for the update Ian Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #485379 7th Aug 2018 10:17am
Andyyav
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
I run these on 36 front and 38 rear, no issues so far, not sure how much difference a few PSI makes!
Post #485426 7th Aug 2018 8:40pm
RiDDO
Thanks for the pressure advice Andyyav, I will try mine on the same and post. --RiDDO
Post #485468 8th Aug 2018 12:38pm
FlyingTrotter
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Just put a new set of wheels with some Grabbers on - love the look and the feel inc the not appreciably greater noise on first drive
Have them at 33 36 but will experiment as we go
Post #487065 24th Aug 2018 9:01pm
TJH1985
Got them here as well - Love them Thumbs Up
Post #487253 27th Aug 2018 9:41am
19sjw
England 2007 Range Rover Vogue TDV8 Tonga Green
Me too,36 front,42 rear. Thumbs Up
Post #487258 27th Aug 2018 10:58am
DrRob
Post some pics please Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #487262 27th Aug 2018 12:02pm
Harlequin
United Kingdom 2007 Range Rover Vogue SE TDV8 Buckingham Blue
Good in snow?
Hi guys
Thinking about getting the Grabbers for my L322
Are they ok in snow and ice? And the road?
Cheers
Mike
Post #496999 29th Nov 2018 9:57am
nearlee
Wales
Same tyres, 42psi all round.
Not sure about snow, but not brilliant on a dry road. Where ok in light mud though. Remember:- amateurs built the ark
Proffesionals built the titanic
Post #497047 29th Nov 2018 5:39pm
Vogue
@42 psi there is no wonder - you are over inflating unless you are running at max gvw, I did around 80k on generals in an L322 and light load pressures are more than ample - they have very stiff sidewalls 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #497057 29th Nov 2018 6:27pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
As above chap. I run mine 34 psi all round and are great on wet, dry roads , mud. On snow they are way better than a road tyre but not as good as dedicated winter tyres.
42 is too much and why they wont grip and the centre of them will wear faster. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #497917 8th Dec 2018 11:51am
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Totally agree. I use 34 and 37 which is fine.
Post #497970 9th Dec 2018 7:58am
