Home > In Car Electronics (L322) > l322 bluetooth fault |
ASH Member Since: 04 Jul 2018 Location: Staffordshire Posts: 15 |
Hi guy's,
20th Jul 2018 5:53pm |
rhjackson Member Since: 26 Apr 2024 Location: Devon Posts: 4 |
Did you get your bluetooth to start broadcasting again? |
26th Apr 2024 3:43pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1461 |
The MOST network runs in series. In the workshop manual is the diagram - just move onto diagnosing the next item in the loop.
26th Apr 2024 8:09pm |
Thankyou I will check this out |
28th Apr 2024 11:15am |
Olaftheviking Member Since: 21 Mar 2023 Location: Surrey Posts: 7 |
I didn’t. Just use a 3.5mm cable to Aux (carefully laid to socket behind centre console and using a right angle cable to help avoid accidental breakage) from iPhone (into apple 3.5mm to lightning adapter) ((via a ground loop isolator stored in the console)). Phone charges off a Belkin MagSafe vent mount. Find the call quality very good. You could also use a Bluetooth to Aux adapter but I found call quality to be worse and music to be awful. |
30th Apr 2024 6:32pm |
