![]() | Home > Wheels & Tyres > 255/50r20 to 265/50r20? ok to add a little width? |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1462 ![]() ![]() |
The second number is the aspect ratio which denotes the size of the sidewall as a % of the tyre width. For example, 255/50 has a side wall of 122.5mm (50% of 255mm width).
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Ok, the profile ratio 45/50/60 etc is a percentage of the width and gives the height of the sidewall.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
ok thanks chaps. got the aspect ratio now!
Oh and what's the 108Y code mean? (I just picked the above as an example)
I think I need a degree in tyres.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Number is the tyre load index and letter is speed rating of the tyre
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
gonna go
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
Greg,
Only just NMJ...... ![]() Greg, take a look at this site. I've found it useful to compare wheel/tyre sizes in the past. https://www.willtheyfit.com/ ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
Mine came to me running 275/45r20 on the Style 19 wheel (including spare), and I haven't noticed any issues so far, although admittedly haven't driven an FFRR on any other tyre sizes... |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1462 ![]() ![]() |
265/50r20 fits fine no issues. I used to run that size.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3787 ![]() ![]() |
On an L322 I would definitely go 275/45/20 - no issues and as near as OEM in diameter you will get for a wider tyre 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Ah thanks chaps. That website https://www.willtheyfit.com/ is very cool Rob, thanks.
I’ll say it ... 275/45 looks |
