![]() | Home > Maintenance & Mods (L322) > 3.6 TDv8 / ZF6HP26 Gearbox Oil Change |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 699 ![]() ![]() ![]() |
I finally got round to changing the gearbox oil in our 124k miles ZF6HP26 equipped 3.6 TDV8 2 days ago (delayed due to me being a wimp & not wanting get underneath while the weather's been foul).
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 524 ![]() ![]() ![]() |
Excellent write up of a job near the top of my list - I have the plastic sump from AF in the garage along with 7l of oil.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8721 ![]() ![]() ![]() |
If you have the sump off and the oil dropped, it’s worth changing the sleeve, after all if it starts leaking a month after swapping out the expensive oil you will be most peeved!!
You've convinced me. Add it to the list... |
disco 3.5 Member Since: 14 Aug 2014 Location: barton seagrave Posts: 37 ![]() ![]() |
hi pawl did you get any quotes by a garage on how much a gear box oil change would cost, mine needs changing but im not confident to tackle it my self, ive been quoted £450, is that competitive LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
When I did my 2007 I bought the stuff from Dan and then got the M.D. to do it, the labour charge was about £100 but that was a few years back. There is nothing that can't be fixed with a hammer😜😜
I didn't get a quote for an oil change, because I'd seen so many comments initially suggesting a "simple" oil change didn't change a high % of the transmission oil. It was only later I realised that these were related to the GM 5 speed gearbox & that the few who'd changed the oil on the 6 speed had all changed the major part of the oil. Via a couple of on-line videos, I then realised it was well within my DIY skills & left me in full control of what was done / not done (I have fully developed paranoia about the reliability / cost of garages ![]() The quotes for the mega flush did highlight that many garages will only use the transmission oil they get a good deal on OR charge very significantly more to use the very strongly recommended ZF Lifeguard 6 fluid. The recommended oil & sump pan / filter cost me about £220 from memory, labour obviously free. That suggests the £450 is a bit high (at least to me), as a garage ought to be able to buy the fluid & sump cheaper & should have facilities which make the job faster than my very leisurely total of maybe 4 hours ( excluding waiting time for everything to drain while I was doing other things / drinking tea ![]() I think the key questions are what fluid are they proposing to use, what will it cost for ZF Lifeguard 6 & are they including changing the mechatronic sleeve mentioned via a few of the posters above. Hopefully you'll get some more feedback on garage costs here soon. Good luck. Paul, 2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 151,000 miles & now sold Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Great write up Paul. |
thankyou pawl for your reply, very usefull information for me to take to the garage, ive got a number of questions to ask them thanks to your excellent write up |
disco 3.5 thanks for the kind offer of work !
Thanks Pawl anyway Im more educated for speeking to you, will search for some mechanic who will use the right parts and who is recommended to do a top job |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
My local specialist quoted £300 for a mega flush oil change on our ‘07 TDV8.......only on 89K presently and running sweet, but will get it done this year. David
what garage quoted you that price bowbrownie LANDROVER HISTORY 2000 DISCOVERY 2 E. 2003 DISCOVERY 2 ES. 2005 DISCOVERY 3 HSE, 2009 RANGEROVER WESTMINSTER |
Triumph72 Member Since: 11 Apr 2018 Location: Argyll Posts: 39 ![]() ![]() ![]() |
Does anyone know if LR does the gearbox oil change as part of a regular Service?
