![]() | Home > Maintenance & Mods (L322) > oil seperator 4.4 bmw bottom pipe |
handyM Member Since: 24 Nov 2015 Location: stockport Posts: 19 ![]() ![]() ![]() |
How do you get a new bottom pipe on the oil separator 2003 4.4 BMW ?
I have found the solution to my problems on the BMW forums
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
This may help if you are planning on doing the job
Thanks for the reply holidaychicken i am going to change just the oil separator and put new bottom pipe on
Thanks for the pics Holidaychicken ,i can now see what i am up against
You could always pop your transmission out !
i think the proven method is as per Saintv8's Wiki and thats laying on top of the engine with something comfortable in place. It would be really comfortable if you got somebody else to do it for you ![]() |
Thanks for the info holiday chicken , i managed to do the job this weekend
Top Job then |
Yep i have got the seals and the landrover oem sealant i have done the front vano seal covers
