![]() | Home > Technical (L322) > My HDC INACTIVE problem sorted |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Decided as it was drier and less cold, to get under the car and see if I could see any obvious reason for HDC INACTIVE. I found this....
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
had similar on speed sensor wire on my car....£17 part, so easy fix |
Just thought, best check other side! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
you might have started a panic here RICH and everyone will be checking their cables tomorrow.. |
It's worth checking when on a lock, as tyre was only touching when on partial lock, and not in the straight ahead.
