![]() | Home > Technical (L322) > Well that's not gone well |
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 ![]() ![]() ![]() |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Plug it and get your codes read, you never know it might not be terminal, but then again..
wack61 Member Since: 17 Nov 2017 Location: Cheshire Posts: 104 ![]() ![]() |
No waning lights on , revs right up to the red line, on tickover it doesn't sound too bad , thing is if you look on eBay there's dozens for sale but few sold listings so it could have stood with no oil in for years
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
Sounds very much like the top end. Have you had the cam covers off to look at it? John
I've used the mechanic that fitted it for over 10 years, he has a lot of experience with diesel engines, he's telling me because it's running on 6 cylinders and revs to the red line he thinks it's the little end because it's too loud to be a stuck tappet problem.
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Give money back for part is ok, but money for work? L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
Money for labour , fat chance of that , at least he's holding his hands up over the engine. |
I found a M57 forum somewhere in Europe on faceache , they're telling me to get the injectors tested as it could be an injector problem , I've never heard an engine sound like that without it being something major causing it , could it knock that loudly from an injector issue |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
The only time I've ever herd anything like that was under extreme load on a very hot engine... so it could be an injector running weak... hopefully you still have 6 spares! Yesterday I couldn't spell Engineer... Today I are one!
Spares of everything, 2 complete engines, I think it needs further investigation before I spend £600 on another engine plus the same on fitting . |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
When the injector o rings went in my D2 TD5 it sounded very similar.
Picked another engine up today only I've seen this one running and I've bought it with the injectors still in it , decided it was going to be cheaper in the long run just to write it off and start again rather than try chasing faults down at £££ an hour |
New engine fitted , got the call today, come and get it, running fine
The main thing is you're back on the road |
