Home > Technical (L322) > 4.4 TDV8 doesn't crank tip
TomCobbly
Over the last couple of days my 2011 4.4 TDV8 wouldn't start. When I pressed the button it just went "click".
Reading posts on the forum I'm thinking battery, starter button, brake pedal switch, relay, fuse, electrical contacts and starter motor.
The battery is new and it started perfectly well the day before so I had a read up in the 20110-2012 workshop manual and found an interesting tip.
Jiggle the steering wheel to take the pressure off the electronic steering lock.
I did this and hey presto it started immediately. Embarassed
I suppose it is a bit like when you have a steering column ignitition key switch which is also the steering lock and you can't turn the key unless you jiggle the steering wheel except in this case the lock is electronic.
Hopefully this may help someone else before they start spending money. It was certainly a big relief to me! Thumbs Up 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #459000 30th Nov 2017 9:22am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Great tip ... thanks Very Happy What do I put here then?
Post #459004 30th Nov 2017 9:57am
Baltic Blue
One to remember. Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #459007 30th Nov 2017 10:23am
carpcat
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Thanks for the tip!
Can I ask where you found the 2010-2012 workshop Manual, as I can’t find one anywhere... Chris
Post #459018 30th Nov 2017 11:18am
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
This seems s similar scenario to steering column/ lock issues with earlier years, as on link.
http://www.fullfatrr.com/forum/topic34364-15.html
Or has the column/ steering lock design been changed on later vehicles?
Post #459020 30th Nov 2017 11:32am
TomCobbly
Carpcat - I downloaded the workshop manual after a few forum members colluded to pay and download sections of it from TOPIX and put it all together. I'm not sure what happened to it. Have you looked on wiki?
Stan might be able to chip in on this one. 2011 4.4 TDV8 Vogue SE
Post #459032 30th Nov 2017 2:17pm
Baltic Blue
Carpcat,
The 2010- 12 Workshop Manual is only available to owners who have been active forum members for over 1 year and made over 100 posts.
Keep posting !!
Cheers
Post #459034 30th Nov 2017 2:42pm
Gumball3000
United Kingdom 2011 Range Rover Vogue SE TDV8 Zermatt Silver
Good tip , seems like another full fat 'qwerk' lol
Post #459040 30th Nov 2017 3:35pm
carpcat
Thanks Tom & Mike. Out of interest, is there an easy way to see how many posts a member has made? Chris
Post #459048 30th Nov 2017 4:53pm
carpcat
Just seen the answer to my own question on my profile Rolling Eyes Chris
Post #459049 30th Nov 2017 4:53pm
mpirie
On the left side panel, under your username.
Mike
Post #459050 30th Nov 2017 4:55pm
