![]() | Home > Technical (L322) > Td6 FBH |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
near side front, above/inside the wheel arch.. ... - .- -.
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Thanks.
loads of info re the fbh on the forum Paul, have a search |
Thanks.
The fbh only cuts in at air temperatures lower than about 5C. If it cuts in then goes off after a few minutes it’s possible it working correctly depending what the outside air temperature happens to be.
I'm lead to believe that if I set the timer it should come on at temps below 15 degrees C.
Where is the pump located? |
Quote “ The fuel pump for the FBH is located in one of the most inaccessible places on the car, behind the upper wishbone of the RHR suspension. One can just about get a hand or finger to it to test if it is running/ticking. If you are really in the mood you can (CAREFULLY!) drop the subframe @ 2in on that side for better access. “
