![]() | Home > Maintenance & Mods (L322) > Bad Fuel pump? |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I did the bypass of the fuel pump relay in the rear right fuse panel with no noise coming from fuel pump. Is this at least 99% indicative of a bad fuel pump? |
This is just an update. Pump is not yet back in but this just made me shake my head.
Wiring attachments are different and they look spliced in. Both hot and ground have bare spots.
The strainer end of the old pump had a smaller diameter. A piece of PVC black pipe and Teflon plumber's tape were used to make a fit.
Here is the piece removed. Now to fix the wiring.
I'm impressed this pump lasted this long. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
That is unbelievable!
Hey I'm all for using what you have in a pinch but then get the right stuff when it's available. This will be interesting to see if the weak pump and bad setup is causing the lambda code by way of lean fuel. I have read it can and another on this forum had the same before his pump went out. |
The beast lives again! Pain in the butt to do. The videos make it look so easy. Perhaps no garage and 50 f degree weather didn't help. |
Good work, 50 def F , that�s quite warm isn�t it ? |
Warm for you folks. 10c is about the 7th circle of Dante's hell for us. Summer averages in the low 30's c for us. Cold and old plastic makes me nervous. The cold made rolling the carpet back impossible so I ran a cord and electric heater to warm the cab. Made it much easier. But once the tank was open I thought it a bad idea to mix petrol fumes and electric heaters.
It�s like all the jobs I do, once you have done them once you could probably do it again in a quarter of the time or less.
So true. What next? Good question. Needs are the following: Headliner, lift gate trim refinishing, Android head unit, parasitic battery drain, left headlight wiper motor, install new radiator (pin hole leak so no rush), install new struts and rear shock (I have a cheap mechanic with a lift for that), new tires this Wednesday, fix left rear passenger seat belt catch, right rear panel rust coming through, left outside A pillar trim replaced, rear washer check valve, transmission drain and filter change, replace air quality sensor, sort out a way to stop the stuck thermostat code from being tripped. I guess the parasitic drain should be on my priority list.
If your left headlight wiper is still connected that could be your parasite too.
I forgot the floppy side mirrors. I did pull the fuse for the wipers a while back. Got tired of resetting it. |
I would be looking at the drain first |
