Home > Technical (L322) > Aux Heater Question
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Aux Heater Question
I set the timer the other morning for the heating to come on and warm the cab, but when I went out to the car I could only hear the fan running (No Heat).
I believe it was cold enough to work. After doing a search this left me more confused as mine doesn't have the Aux Heater tick box on the menu.
My first question is does this effect the pre cabin heater and if so can I get it programmed to show this option.
forgot to mention mine is a 2004 model
Post #455862 1st Nov 2017 4:51pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Same here regarding heater not listed on the computer, and I'm still baffled as to whether it has one or not?
Post #455875 1st Nov 2017 6:32pm
mjdronfield
I enabled it on my td6 with a diag tool and it appeared in the menu.
Will look for the thread.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #455878 1st Nov 2017 6:44pm
mjdronfield
Here we go....had to enable Aux Heat as well as Aux Cooling...
http://www.fullfatrr.com/forum/topic30560.html?highlight=heat
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #455880 1st Nov 2017 6:48pm
matlandy
So I have read the post and it mentioned that you need to have a change over value fitted also.
So What does this look like as have search google and none the wiser and where is it fitted to the car.
Post #455905 1st Nov 2017 10:50pm
mjdronfield
All diesels had the heater as standard..... I assume you have a td6 as you have not filled in your car profile yet.
Do you have Aux Vent as an option in the menu? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #455906 1st Nov 2017 10:57pm
matlandy
Yes I have the the TD6 model and it has aux vent displayed on the screen on the dash board.
Post #455907 1st Nov 2017 11:00pm
mjdronfield
Mine was like that. It will only blow the air from outside in, to “vent” the hot air out in the summer so the car interior is no hotter than outside....or thereabouts.
If you want it to heat up in the cold weather, you will have to enable park heat with a diagnostic tool. You will then have an extra menu option....
Till you do that, you will be getting nowhere I’m afraid.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #455910 1st Nov 2017 11:07pm
mjdronfield
Think this was the post I was looking for. Thought I’d posted more than the thread above....
http://www.fullfatrr.com/forum/topic14026....=park+heat 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #455912 1st Nov 2017 11:13pm
