Home > Maintenance & Mods (L322) > Front Drive Axle & Rear Differential DRAINING & FILL
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
What to do to CHANGE Both the FRONT & REAR Diff Axels - with NEW OIL
1. Ensure you can remove BOTH the filler bolts on each Diff - BEFORE you take out the DRAIN Plugs - Its better to know you can fill them than find out ones seized.
2 . Ensure you have enough CASTROL SYNTRAX LONGLIFE 75W90 Synthetic GL5 Gear OIL - DO NOT USE ANYTHING ELSE. - Always have DOUBLE the quantity required to finish the job - in case something goes wrong.
3. see Quantities stated below - DO NOT OVERFILL & DO NOT UNDERFILL
FRONT DIFF
1. Remove Engine under shield
2. Clean the surrounding area around the Front Diff Case Plug - CHECK to see if you have had any leaks ( Important )
3. Remove the FILLER PLUG FIRST - Better to be safe to ensure you can fill it up - with a old plug stripping or seized plug
4. Remove the DRAIN PLUG and drain the fluid
5. I ALWAYS USE BRAND NEW PLUGS / BOLTS where ever I can - NOTE: I always put a bit of Plumbers Teflon Tape better known as PTFE top ensure a tight seal.
see pic below: ( shows the TRANSFER BOX BOLTS with PTFE tape on - this tape I lightly coat the Diff Threads to ensure 100% seal
6. Instal the FRONT Diff DRAIN PLUG back in - Tighten to 54Nm ( 40 ib.ft )
7. Fill the FRONT Diff casing upto: 750ml ( you will know when shes full as it will start to come back out of the filler plus DO NOT OVERFILL
8. Torque the Filler plug to: 35Nm
Pic of my Front Diff below:
REAR DIFF Filling:
NOTE: ENSURE you only have a OPEN Differential and NOT a ETM Differential - as the Fluids and fill quantities are very different
A) OPEN REAR DIFFERENTIAL
B) ELECTRONIC TORQUE MANAGED (ETM) REAR DIFFERENTIAL
This only applies to version A: OPEN REAR DIFFERENTIAL
1. Remove the FILLER PLUG FIRST
2. Remove the DRAIN PLUG Next
3. Drain the Rear Diff fluid
4. USE A NEW DRAIN PLUG - see pic above
5. DRAIN PLUG - Tighten to 28Nm
6. Fill with the correct fluid see above - again ensure you DO NOT OVER FILL OR UNDER FILL - you will see it come out of the filler plus - Quantity should be: 1.14 liters
7. Insert the NEW Filler plug are tighten to 34Nm
Picture Below:
THIS IS WHAT TO USE - TO FILL THE DIFFS UP - IT HOLDS FLUID - AND IT GOES IN 100% - NO SPILLS x
IF YOU ARE GOING TO DO A JOB - DO IT 100% and Don't Mess Around - Perfection is key
Wipe all areas clean - check again in a few days time to ensure no leaks
As this is such a simple job ( you may ask your wife to do it next time ) - I strongly suggest you do this every 20,000 miles on both the Front & Rear Diffs - although LR recommends the oil to be changed at 75,000 miles intervals - I am sure you would agree OIL never lasts that long and the cost and time to do such a simple job is a no brainier.
******IMPORTANT ****
NEVER GET UNDER THE RANGIE WITHOUT Axel Stands supporting her - and set to Rangie to MAX off road Height - ENSURE YOU HAVE ENOUGH AXEL STANDS TO FULLY SUPPORT her if she decides to lower to access height - they can and they will one day - so be warned and be prepared - SAFETY FIRST ALWAYS
I have ramps in the workshop or outside she goes onto Railway Sleepers which weigh a Tonne and worth every penny
I hope this helps anyone
Post #454953 22nd Oct 2017 6:16pm
GGDR
Brilliant post thanks Emirates.
I think I can do that!
And I'm sure Stan will put this straight into the Wiki section.
One question, where do you get the plugs from? Do you use LR parts?
Thanks again.
Greg Cheers, Greg
Post #454956 22nd Oct 2017 6:27pm
GGDR
...one more - on the other post you mentioned LR copper washers but you've not mentioned these here. I take it this is for the Transfer Case?
Thx, Greg Cheers, Greg
Post #454958 22nd Oct 2017 6:29pm
another great 'how to'...wiki'fied.. Thumbs Up ... - .- -.
Post #454963 22nd Oct 2017 7:16pm
EmiratesA380
Thx, Greg
Hey Greg - ONLY THE TRANSFER CASE USES LR COPPER WASHERS
Not The Front & Rear DIFF - on these just use PTFE Tape - They are a tight fit - DO NOT PUT TOO MUCH PTFE tape on - you just want a nice tight seal.
again hope this helps you
Post #454968 22nd Oct 2017 7:31pm
EmiratesA380
Greg - On a Rangie ONLY USE Genuine LR parts - Bolts, nuts / threads / washers - never use third party items and such as hell not from Ebay - hell that would be bad !!!
Post #454970 22nd Oct 2017 7:34pm
GGDR
Roger that.
Thanks again for these posts, great stuff.
Greg Cheers, Greg
Post #454977 22nd Oct 2017 8:29pm
GGDR
That's a 14mm allen key right?
. Cheers, Greg
Post #454978 22nd Oct 2017 8:32pm
EmiratesA380
Greg - you check yours
Just ensure you have a TIGHT fit Allen key - Tighter the fit the less the head will wear on the plug.
ENSURE - the car is fully supported before you go under her - IF YOU HAVE SELF DEPLOYING SIDE STEPS - as I have - LOOSE THESE IMMEDIATELY - they would slice you in half if the Rangie decided to sit down !!!!
SAFETY IS PARAMOUNT in Everything we do - NEVER TAKE CHANCES x
Post #454979 22nd Oct 2017 8:41pm
Tight777
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Is it just me that can't see any pics?
Post #466943 2nd Feb 2018 10:40am
there are no pics..
many members linked their pictures to third party hosts like flicker etc...these hosts started to charge so many members deleted their accounts so the pics were lost..
the forum does allow you to upload pics onto its server and therefore they will be safe... ... - .- -.
Post #466951 2nd Feb 2018 11:10am
p38arover
Australia
Re: Front Drive Axle & Rear Differential DRAINING &
Why?
I use Aviation Sealant No.3 (Non-Hardening). https://www.permatex.com/products/gasketin...nt-liquid/ Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #469276 19th Feb 2018 1:01am
counter of beans
England 2012 Range Rover Vogue TDV8 Santorini Black
To add to Emirates 380's excellent post; I have a 2011 TDV8 4.4 and the rear diff is the electronic version. So it's a little bit different from the details above, specifically:
*you need 1.5 litres of diff oil, Castrol SAF Carbon Mod Plus spec (different from the front diff oil)
*the drain plug is a 3/8 inch square socket - you can use a 3/8" ratchet for this
*the fill plug needs a Torx 50 driver/bit
Also worth noting that the drain and fill plugs on the transfer box need 8mm Allen bits (I think Emirates suggests 16mm bolts in the Wiki section).
It really annoys me how manufacturers use a pick 'n mix approach to their various nuts and bolts.
Post #471367 6th Mar 2018 5:32pm
carpcat
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
I have all the parts to change the front & Rear diff, and transfer case oils. However, I assumed I didn’t have the electronic version of Rear diff, but reading about the square drain plug (which Dan from Duckworths believes I have), I’m now wondering. Is there an easy way to find out which version of Rear diff you have without getting under the vehicle? Chris
Post #471393 6th Mar 2018 7:55pm
GGDR
Chris get your VIN and go onto the topix website. In a few clicks you'll find your build sheet which should say.
How much did all that come to then?
. Cheers, Greg
Post #471398 6th Mar 2018 7:58pm
