![]() | Home > Technical (L322) > Diesel Leak |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Noticed a smell of Diesel when I parked up earlier. Seems to be coming from rear of RR
Check the FBH (Fuel Burning Heater) pump (Rear Right above upper wishbone) and pipework (from there to tank and to under Left tank cover) .
Thanks Joe I think you are spot on with your suggestion.
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
I've got no experience but given my own leaks (onto the diff but from the diff seal) I thought I'd look it up.
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
i had the same problem it was the fbh pump the end had rusted off the pump . |
Thanks guys, Instructions make it look easy.
You can give yourself a bit more space by getting some jacks under the rear subframe and releasing the subframe mounting bolts and lowering (gently) that side.
Got the pump changed today. Decided to do it from under the RR. One arm either side of the diff and I managed to get it done.
