Home > Technical (L322) > Td6 starting issue.
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Td6 starting issue.
I fitted a new alternator to our Td6 on Sunday. All was well until yesterday when the car refused to start. My wife called me to tell me, she tried it again and it started straight away. It did the same again this morning. Apparently it cranks over fine but there are no ignition lights showing on the dash.
The alternator change may well be unrelated.
Any ideas?
Post #450883 14th Sep 2017 8:49am
GDM
Looking at other posts it seems that there can be problems with the contacts on the ignition switch. I have noticed a few people have had a situation where they have the ignition lights but the car won't crank over and this has been down to dirty contacts. I guess I could have problems with the contacts that supply the ignition feed.
Post #450951 14th Sep 2017 11:00pm
Sandyt
Are the ignition light on before it is cranked ? If so I would say connection at the alt needs looking at worth checking battery connections too
Post #450977 15th Sep 2017 9:42am
GDM
No ignition lights at all before it is cranked, so I think it must be the switch. Have ordered a new one which should be with me on Tuesday.
Post #450992 15th Sep 2017 11:47am
GDM
Fitted the new ignition switch this evening and it started up fine. Bit of a fiddly job, took over an hour but I could probably do it a lot quicker now I know how it all comes apart. Still cant believe the cost of the new switch, £98-00, even at Land Rover prices, is a rip-off.
Post #451457 19th Sep 2017 10:56pm
Sandyt
Oh they know how to take your cash
Hope it is a good fix Thumbs Up
Post #451474 20th Sep 2017 8:43am
