![]() | Home > Technical (L322) > Split inlet manifold |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
can it not be plastic welded pal ?? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Mikeyp has recently had the same problem.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I believe Andy has the 3.6
Andy Cox Member Since: 24 Dec 2016 Location: Cornwall Posts: 45 ![]() ![]() ![]() |
Sorry for the delay in getting back to you PaulB, very limited time to get on line at the moment. Also, I should have made clear I have the 3.6 as Paul correctly says.
That's a great help Andy, thanks.
Hi Paul
Thanks Andy
When it first started happening, I was in Hampshire for a few days and took it to Keith Gott and they did scan it. I'm afraid I didn't see what the code was but it was picking up a mismatch between the air flow sensors and the manifold pressure sensors indicating a leak in the induction system somewhere.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Nice temporary fix. Well done. ______________________________
The weather has been amazing Andy, especially today.
Glad to hear you're enjoying the weather Paul. My guess is a smoke test would be more revealing as you would physically see the leak.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
You could try and see if these guys can help you out!
Thanks for that Stu.
