![]() | Home > General (L405) > Stolen !!! |
Charlyfarly Member Since: 26 Jun 2015 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Hi all,
Update 3.32am.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Sorry to hear!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
sorry to hear this...
That sounds about right. Both keys were in our bedroom but near a window. The tracker people have told me that they got a "tamper" message when the car was about 10 mins from my home. I assume that's because the key fob was not present. They tell me that the tracker is no longer working (been disabled?) but they may be able to do some sort of GSM triangulation once they have the necessary data protection permissions from me and the local plod. Sadly, I suspect my beloved car is gone for good. If it ain't broken, fix it till it is. |
i suspect you wouldnt want it back even if they found it.... ... - .- -.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Sorry to hear that.
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1108 ![]() ![]() |
Presumably the tamper is them disconnecting the tracker, how can it be that easy? letters not necessarily in the right order |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
Scum bags. Unbelievable how easy it can be , keep us informed and good luck. |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
OP Sorry your car has been stolen . Can we presume from this that the location of the standard tracker is out in the open ?
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
ah |
If you put your keys in a tin or metal box it acts as a faraday cage and should stop the "key repeater" thefts . Still trying to think of a solution when you have the key in your pocket . My Yamaha tmax key has a on / off button on the fob so as you walk away you can switch the fob off , something for the next model !!! |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1464 ![]() ![]() |
Thieving fu
Could they not have disabled the vehicle remotely when they realised it was stolen and knew where it was. My very basic tracker has an option to cut fuel supply etc which at least stops them getting too far. Hope it works out for you ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
@CUE99T
