![]() | Home > Technical (L322) > Lost all keys |
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 ![]() ![]() ![]() |
Or disconnect the props at the UJ's as they enter the diffs and let the handbrake off and it will roll, put it on a flat bed then take it to the dealers. 2004 4.4V8 Vogue
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Cheers, that's another option.
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
I would think best thing to do would be call breakdown company let them.grt it to dealers, already wasted £200 on non functioning key
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 ![]() ![]() ![]() |
I've just ordered a new key from Land Rover. It came ready cut and programmed to my car. Just had to add it to the memory with the coding process as in my other post in here. Don't think he would need an original key to follow this process. RR History
He did try the dealer and they said they wanted the vehicle taken to them.
See here. http://www.fullfatrr.com/forum/topic42668.html
Thanks for the thread, i need to PM Dan, where are the stickys please ?
If he needs to move the car in the meantime just lift the leather gaiter for the gear lever off and there is a mechanical override for the park brake under there but I can't see why it has to go to the stealers in the first place. 2008 MY Supercharged
Thanks , I'm learning a lot with this thread, I'll call round his house later and get the vin and email it over to Dan at Duckworths asking what the procedure is.
Ok, bit of an update- got a quote from Dan at £148 but key will still need to be programmed by a specialist or car taken to dealer.
And another update..
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7997 ![]() ![]() ![]() |
As far as I know, the key needs to be paired to the car.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
good to know that his pain will benefit us all in the long run , I always thought a dealer sourced key would work form the get go but clearly not |
Cheers guys, this is made so much more difficult by the fact that the guy my friend chose to replace the key is a bit of a numpty.......
