![]() | Home > Technical (L322) > HDC off and air suspension inactive and abs light on. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1364 ![]() ![]() |
you NEED to get the codes read
sarn Member Since: 05 Apr 2013 Location: Oswestry,Shropshire Posts: 27 ![]() ![]() ![]() |
Ditto - or as with my ff broken wire between left rear sensor and ABS unit in engine bay. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3215 ![]() ![]() ![]() |
Any one of the sensors in the Canbus can trigger all these lights, even tho it may only be one sensor at fault.
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 224 ![]() ![]() ![]() |
Turns out it was a "camber sensor" stuck or been nudged, happens when you have all 4 wheels off the ground and turn the steering to its lock.
Edisback Member Since: 10 Jun 2017 Location: Surrey green lanes Posts: 2 ![]() ![]() ![]() |
Glad it's resolved.... although how by the mechanic is unclear....
