![]() | Home > Wheels & Tyres > Thinking of changing to 18" wheels...... |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
I'm currently running my 2006 FF on the standard 19" with 255/55 19 tyres but I'm thinking of changing to an 18" wheel.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3263 ![]() ![]() ![]() |
Don't know if this helps. http://www.fullfatrr.com/forum/topic32993....+18+wheels
Thanks Weggie, I did a search but missed that one........ |
Sorry can't really comment on the 285 tyres. John
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Check the loading on the tyres are upto what LR specify for the 18". Iirc the load is 112 but could be wrong. There is nothing that can't be fixed with a hammer😜😜
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
With a td6 you will have a range of LRrims to choose from for a 285 tyre. Just make the offset is ok, load capacity is at least 900kg (especially if at normal speed on 2nd class roads), is 8" wide and is genuine LR rim. There are other good brands such as componotive. Just keeping it simple.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Why don't you fit 255/60/18's that is the correct tyre size for 18"wheels and there is no clearance issues |
Good point, I think the tyres I have are 113V, rated at 1150kg so should be ok, it's currently fitted with 111v. @ rav110, thanks for the info., but are you saying that a 285 tyre won't fit in the wheel well? I'm getting different information on this, perhaps depends on the offset of the new rims, I guess fitting is the only real way of knowing. According to the comparison calculator the between 255/50/19 and 285/55/18 would be +1% in diameter and circum., +12% in width and +12.7% in sidewall. https://tiresize.com/tyre-size-calculator/ @ Miggit, I'm only considering 285/55/18's because I already have a set sitting at home (and I like the wider look tyres..... ![]() |
I tried a 285/60/18 in my L322 wheel well and it was too big. Even a 275 will be too big.
Thanks again for the info., but I'm a bit confused, where exactly did your 285's not fit?
increase in width will be 30mm so thats 15mm each side. if you have less than 15mm clearance between the inner sidewall and any components then it will foul, thats about a fingers width. There is nothing that can't be fixed with a hammer😜😜
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 614 ![]() ![]() ![]() |
Surprised there's so much doubt about this. 285 isn't all that big. I've had 275 20s on two of my 322s and never had any issues with clearance (or anything else). Indeed I believe it was a "standard" oversize (Stormer alloys?) supplied by LR and was for sale in a main dealer near me for <£800 incl tyres.....at a time when I needed new tyres - so a no brainer for me at the time (on my '02). I think the car looked good on them, but obviously they didn't work as well for anything other than tarmac driving. I also had 275 Grabbers on my 4.2 SC an they worked well for me on and off road - although I see that Chris was keen to change them as soon as he could after he bought it! Mike - MPx
Thanks again guys, I think it's the offset of the wheels I'm looking at that could make the difference, there isn't a whole pile of room between the current wheel and the front strut but if the wheels I'm looking at have a different offset (in the right direction) then hopefully there won't be a problem.
Standard sizes
