Home > Maintenance & Mods (L322) > DIY Spare Wheel Lifting Strap
nino_nino
After removing spare wheel once, i decided i needed a lifting strap.Found two on ebay ~ 50 euros and with customs and VAT
I was looking at around 120-130 euros.So decided to make my own and this is what I did.Cost 8~9 Euros and couple hours of work.
It works great.
Post #430082 5th Mar 2017 3:13pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Well done... Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #430085 5th Mar 2017 3:57pm
Post #430097 5th Mar 2017 5:34pm
Baltic Blue
This looks so good, you should make up a few and sell them to us OAP over 65 members at a special discount rate of 25€
Very Happy Very Happy Very Happy G reg 2.5VM Vogue Portofino red 1991- 1999
Post #430102 5th Mar 2017 6:03pm
nino_nino
Hey BB, you may be onto something , if I can sell 10000 I'll can bay new L405.
Wanna be my agent? Very Happy
Post #430122 5th Mar 2017 7:41pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Mine came with the lifting strap, I thought that was a standard feature on all???
Also the Factory one also comes with a plastic locking bar that prevents the tailgate lifting when you use the strap when the weight of the spare is on the strap , a safety device to save the family jewels
location as per pic attached
Post #430171 6th Mar 2017 3:43am
nino_nino
I do have one, aluminium one, no cheap plastic here, however my setup balances fine without one so I didn't include it in the pictures.
As for it being supplied with the car I believe that later models did not come with it.
Post #430218 6th Mar 2017 1:04pm
Baltic Blue
What length is each strap please?
I am going to buy some strapping and copy yours. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #430227 6th Mar 2017 2:31pm
nino_nino
BB, here is my material list :
Al. pipe ID 22 OD 25 X450 mm
strap 26mm W x 1700mm (2)
oak flooring 58x21mm x 100 mm
wood dowel 22 x 140 mm
10mm bolt (2)
washer 37x2.8mm (2)
Al. U channel 15x15x2mm 400 mm (for the locking bar)
I have used 80 grit sandpaper to make a chanel in the wood and epoxy and wood screws to fasten the insert to the pipe.
it is important to use tight fitting wooden dowel inside the pipe where wood screws go in.
Post #430245 6th Mar 2017 6:31pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Thank you Nino!!Copied your DIY successful.
The fool at LR that decided that this aid was not needed anymore should come show me how to take the wheel out....on his own Whistle Whistle Whistle 2012 TDV8 Vogue SE 4.4
Post #453826 12th Oct 2017 1:44pm
GavinBell
Romania 2012 Range Rover Westminster 4.4 V8 Santorini Black
Looks good - how about adding a strap through wheel to help pull it out once it is raised Series 2a LWB Hardtop - ex British Aerospace that was then used in an armed robbery! not by me!
2 door V8 1979 Range Rover
A slight Subaru blip..
110 County 200tdi
R reg 300 tdi Discovery Aviemore - gone to a local enthusiast to be resurrected in Transylvania
2003 TD5 Discovery2 - now sold
and the 2 wheeled Range Rover - BMW R 1150GSA
and finally the big lady of my dreams... 2012 Westminster - gives me a smile every morning
Post #453832 12th Oct 2017 2:22pm
nino_nino
Very Happy Thumbs Up
Post #453835 12th Oct 2017 3:50pm
Beemergriff
Thanks so much for all of the details. I have the time and tools to do it, and likely most of the materials, with a few modifications - just need to get some webbing Cool Andrew
Defender 300tdi
RR Classic Off-road Trialer
BMW X3 E83
BMW 330 E46 convertible
Post #528250 16th Sep 2019 5:11pm
OmoBeanz
United States 2009 Range Rover HSE 4.4 V8 Stornoway Grey
Hey guys, new to the forum but I have already gained a lot of useful info from it! I was following this guide and decided to create a 3d printed version with handles to help lift the tire out.
https://makerworld.com/en/models/1349886
Please let me know what you think.
Note: I did not glue these to the pipe, they are just press fit. That way the handles can be rotated around to the lock tab side when not in use for easier storage.
Post #716657 23rd Apr 2025 5:59pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Genius ! Is it possible to upload to Printables ? I’m assuming of course you’re happy for it to be shared !
My 12 yr old does all the 3D printing - I watch in awe.
Cheers
Jonny
Post #716678 23rd Apr 2025 10:07pm
