Home > Technical (L322) > 2006 side-light/headlight bulbs??
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
The dipped beam head-lights on our 2006 L322 seem to be quite poor, even though it has xenon head-lights.
Looking at the lights this evening, there is an additional bulb in the same housing as the side-light bulb. These look to be a removable halogen headlight bulb but they don't come on with either main beam, or dip. What are they supposed to do?
Thanks,
Glen.
Post #421021 3rd Jan 2017 9:21pm
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Cornering lights.
Post #421023 3rd Jan 2017 9:36pm
as i have done Glen, you can adjust the headlights up a bit so the light spread is better...
some members have bought some philips or osram replacement bulbs that claim to give extra beam power..
Post #421024 3rd Jan 2017 9:40pm
GDM
Flyingfocrs wrote:
Cornering lights.
Could be. Do they only come on when turning?
Post #421047 3rd Jan 2017 11:47pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Does yours have the separate indicator unit?
Post #421048 3rd Jan 2017 11:49pm
GDM
Stan,
Yes, I was contemplating adjusting them up before I realised that these other bulbs were there. It has just been MOTed but it seems that most garages adjust them down, if they are too high but not up, if they are too low.
The primary main bean and dip head-lights are xenon, so no possibility of a bulb upgrade, and with the xenons it shouldn't need them.
Post #421049 3rd Jan 2017 11:50pm
GDM
Indicators are above the side-light but still in the main front light housing.
Post #421051 3rd Jan 2017 11:52pm
Flyingfocrs
GDM wrote:
Flyingfocrs wrote:
Cornering lights.
Yes, on cars without the cornering light there is a chrome blank in place of the bulb.
Post #421064 4th Jan 2017 1:50am
GDM
Just found out that the xenon bulbs can be replaced, I didn't realise, I though that they were a sealed unit. Have found some Osram Nightbreaker bulbs that claim to give 70% more light, so, if adjustment doesn't work, these will be the next option.
Post #421360 6th Jan 2017 12:18am
GDM
Looks like both the cornering light bulbs might be blown, as with the car running and stationary, turning the wheel from lock to lock does not make them illuminate.
Post #421839 9th Jan 2017 12:34am
