Home > Technical (L322) > Refilling problems on my L322 FFRR TDV8
Smee55
Scotland 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Hello
I'm new to this forum and new to owning a Range Rover. My car has developed a problem when refilling. At the pump it is taking me ages to fill as it keeps shutting off or spits back. I have tried putting the pump nozzle in at various angles but the problem still persists.
I would be greatful for any info on how to stop this problem.
Many thanks in advance
Ian R aka Smee55
Post #415537 27th Nov 2016 10:32am
mjdronfield
You need to reset the misfuel device.... you should see something yellow blocking the filler. You should have a yellow plastic tool to do this. It's in the manual....
Or at least try that first...
Even when reset I can't put the nozzle more than a couple inches in or it triggers again on mine.... I recon it's bust to be honest.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #415545 27th Nov 2016 10:50am
Jambo
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Exactly the same happened to me the first time I filled it up. Took a while to work out what it was, but resetting fixed the problem.
You should find the yellow tool in the boot by the spare wheel Thumbs Up
Post #415555 27th Nov 2016 12:41pm
Smee55
Hi guys
Thanks for the info, will check as soon as my wife returns the car after a weekend away.. Smile
Post #415571 27th Nov 2016 2:01pm
Realist
Wales
I removed mine all together saved this hassle. Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #415574 27th Nov 2016 2:07pm
Smee55
How did you remove the fuel stop.
Post #415575 27th Nov 2016 2:10pm
mjdronfield
I'd remove mine if I knew how.... I can't even put the correct nozzle in far without it triggering.......
My td6 didn't have one, so it really caught me out on the 4.4.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #415580 27th Nov 2016 2:34pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I always put the hose in with it turned through 180, looks a bit odd but can get full flow.
Ian
Post #415677 28th Nov 2016 10:05am
peekay
2016 Range Rover Autobiography SDV8 Corris Grey
/\ /\ Exactly this - a bit of a strange approach but it works. I heard about this trick from a mechanic in a pub - thought it was nonsense until I tried it and it worked. Don't seem to have same problem on L405
Post #415688 28th Nov 2016 11:56am
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
same here - turning the nozzle upside works fine for me. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #415690 28th Nov 2016 12:18pm
Trebaix
Yep - turn the nozzle upside down 180 degrees.
Colin
Post #415781 29th Nov 2016 6:43am
