![]() | Home > Maintenance & Mods (L405) > L405 Tow Hitch |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Evening
You can buy the deployable kit from Dan @ Duckworths. (if you're loaded)
Thanks, i will be looking at the Westfalia version i think |
I very rarely tow anything these days but you can bet your bottom dollar that if i have a car without one i'll need 6 times in a month. Quite happy to remove the panel when required.
Jay, the Westfalia removable one on PFJ requires that you change the under-tray-cover thingy at the back. It is pre-cut to allow the towbar to be fitted without removing stuff first. |
Have done several now Jay... Let me know if the car you choose is less a tow bar and i will get a quote up together for you ![]() |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
Be nice if we could have a comparison table of pros and cons of the different versions vs the RRP from LR or Dan.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
I had removable on my L322 & have deployable on my L405
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 413 ![]() ![]() |
I had a Westfalia detachable bar fitted and it looked like this above when in use. I did buy a cover with the section cut out to tidy up the look but it didn't fit so just carried on with it looking a bit ugly.
cheers chaps
You won't get near £1000 for the deployable unless the dealer is paying towards it. The parts cost alone is £1700 at super discount from a forum sponsor. I do agree it is the best option but so far the best I can get is £1800 fitted, and that's from a good friend who is DP at a main dealer. |
Agree - deployable is a £1k factory option, but £3k retrofit...... |
I'll see if I can work some magic this week with Pentland MD. all smug in my new plug!
Dte1 Member Since: 08 Apr 2015 Location: Worcestershire Posts: 6 ![]() ![]() ![]() |
Does anyone know if there is any height adjustment on an L405 electrically deployable bar, I have a big mismatch in towball/hitch height (about 60mm) low on car side. Thinking new low profile tyres on trailer may be required. 4 tyres & spare. |
