![]() | Home > In Car Electronics (L322) > Reverse camera repair / upgrade |
Kinch Member Since: 08 Aug 2016 Location: Idaho Posts: 45 ![]() ![]() ![]() |
Okay, I'm indicating with the wire cutters, which location do I want to cut? Right behind the camera, or just before the yellow and red connectuons?
Angus_bull Member Since: 17 Apr 2015 Location: Fauldhouse Posts: 7 ![]() ![]() ![]() |
Don't cut any wires off the camera especially close to the camera as there is a small power convertor inside the large moulded plastic half way along the cable. I did this with my first camera and wrecked it.
Here is the camera that I bought, I then unscrewed the front part and was left with this I trimmed the front part and screwed it back on then put it in the housing For the loom I connected the power and signal cables together and added heat shrink to tidy it up Lastly, excuse any spelling mistakes as I'm typing this on a tablet |
One more think, you will need to dig out all the old resin from the rear of your old camera casing and drill it large enough (12mm if I recall) for the plugs and large moulded section to pass through. These will also go through the spoiler fine if you remove the riveted holder then refit.
Angus thanks for the post. Before you made it, I did the job wrong and ruined my camera. I'm trying to wire it back to see if it will at least work. I'm going to post some photos to show you what I did. |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
Good luck with that, i did the same first time as i did not think the plugs would fit through the hole in the spoiler, tried to wire it back but gave up, they only cost around �8.00, so i would buy another.. |
Okay Angus, so here are pictures of how I did it the wrong way lol. I also took a dremel to the camera and made it smaller in diameter so it would fit in the original housing. Anyway check it out.
I am still struggling with getting a connect via the yellow rca cable, i have cut it and it give a black and red wire, on my test bench both need to be connected to get an image on a tv, but the rangerover loom only has the coaxial type connection how do you connect that in ? Or can you buy and adaptor to plug from the yellow rca cable into the brass coaxial type? |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 ![]() ![]() ![]() |
Mine has got the black screen of death also after some intermittent working, notice there is condensation in the housing so ive ordered one off Ebay to try this fix also, any more info about soldering the new camera leads to the original camera leads would be useful, as I understand going from the new camera to the coax type connection looks tricky?? |
themule Member Since: 03 May 2016 Location: Yorkshire Posts: 126 ![]() ![]() ![]() |
My new camera has now arrived, it's a different design to these though (it has 6 LEDs for night time reversing) and I have taken it apart with the idea of just replacing the circuit board / lens. It has 3 wires coming out, +ve, ground and video. There are 4 wires into the old camera, 2 power, the others presumably being video and the shielding for the coax - not sure how to 3 into 4 goes .
I am missing something here. The cameras have 3 wires, 2 power and the composite signal. I don't see how the single composite signal wire connects to the SMB (coax) cable that has two connections. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
the earth on the power doubles up as the shielding on the coax..[if that makes sense] ... - .- -.
Thanks Stan. So The black earth wire splits, 1 bit for the shielding and 1 for the power earth? That would explain the moulded part on the new cable, which I cut off. |
thats what i've found when doing my home cctv .. ... - .- -.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I did only a minor trim on the bezel at the focal end of the unit. It then went into the existing housing with no fuss and after it was aligned and shimmed, I back filled it with silicone and allowed it to set. There is no direct plug and play, I soldered the neg to the shield and it's working just fine. I used heat shrink and insulation tape to ensure it is protected. A bit gung ho for some of you more refined but I needed the camera! Is this where I put the car details and a bit about myself ?........ |
