![]() | Home > Maintenance & Mods (L405) > TDV6 Oil Service |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Id think yours has a faulty sensor sir...! |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 ![]() ![]() ![]() |
Well its going in tomorrow for a diagnostics check so we shall see. i will be a bit disappointed if I end up having to have an oil service every 5-6k miles! 2021 L405 Vogue D300
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
I'm sure you won't be paying either way but suspect it's just not been set up right. Mine is still showing that it needs a service on incontrol even though it had a service last week, seems that the dealer forgot to set the thing up and it means another trip to a dealer just to reset it. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Given the number of failures on the TDV6, it sounds like you're doing the right thing - take it straight in & let them sort it out - you can't afford to ignore any warning as it gives them warranty wiggle room...... |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I experienced the same problem. There was no need for a service before 12 months or 16,000 miles whichever came first. The Incontrol app also told me I needed a service. The dealer reset the service indicator when I booked it in because of the faulty message. I have just had a first service at 15,700 miles. I think the software may have been upgraded to fix this error. |
Not aware of failures on 2016 TDV6. Can you enlighten me? |
I didn't specifically say issues with the 2016 TDV6 - but you know the thread
But in that thread the OP says in a post dated 6 July 2016 that the problem was a known one that affected a wide VIN range up to early 2015.
Dealer did an oil service under warranty citing that that it was a bit early. No issues with the sensor but they claimed that DPF regeneration can lead to oil degeneration.
Interesting to note that I have never had a DPF warning on the car before, I guess the car does also not warn you of the oil level rising also. My car does a lot of short journeys in the week so I guess this is the cause of the partial regeneration and the oil break down. 2021 L405 Vogue D300 2016 L405 Vogue 3.0TDV6 (Sold) |
Diesels & short journeys don't seem to mix well - a good italian tune up every once in a while should help - discussed a bit on this thread |
