Home > Technical (L322) > Key third button programming
JPHC
Extract from Disco3:
Quote:
Program the key fob 'Land Rover' button
The Land Rover button of Discovery 3's key fob (bottom of the 3 buttons, with the 'Land Rover' logo on it) can be programmed to do one of four things - trigger the panic alarm; turn on the 'follow-me-home' headlights; raise or lower the suspension; or release the upper-rear tailgate.
To set the panic alarm, insert the key in to the ignition (position two) and then remove the key from the ignition. Immediately after, hold down the Land Rover button on the key fob whilst pressing the hazard warning light button on the dashboard.
To set the remote to turn on the headlights, insert the key to position two and then remove it. Hold down the Land Rover button on the key fob whilst flashing the headlights (by pulling the headlight control stalk). The amount of time the lights remain on for depends on the headlamp delay setting (which can be changed within the Settings menu of the digital display).
To set the remote to raise or lower the air suspension, turn off the engine and remove the key. Within one minute, press and hold the Land Rover button on the key fob whilst pressing the air suspension control lever on the Terrain Response area of the centre console (to either position, up or down). The suspension can then be adjusted using the remote key fob. The hazard warning lights must first be turned on and all doors closed. To raise the suspension, hold down the Land Rover button whilst pressing and holding the lock button. To lower the suspension, hold down the Land Rover button whilst pressing and holding the unlock button.
To set the remote to release the tailgate, press and hold the Land Rover button on the fob and then release the tailgate (either by opening in outside or by pressing the Lock and Unlock buttons on the dashboard together).
Want my 3rd button to operate my lights, not pop the boot, so tired above method but all i get is a message on the dash saying "Headlight Delay" and the key still pops the boot. Is it a different process for L322?
Thanks, Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #404060 8th Sep 2016 4:33pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Shocked Idea never knew that. Will try tomorrow Thumbs Up
Post #404067 8th Sep 2016 5:17pm
Won't work on an L322 Crying or Very sad different Body Processor Unit and it's not there . 2008 MY Supercharged
Post #404132 9th Sep 2016 6:47am
JPHC
Thanks axle...Annoying though Big Cry Jordan
'56 SC 4.2 ‘16-‘18
Post #404143 9th Sep 2016 9:45am
