Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8160 |
The reason is stated in the first post.....
Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
16th Oct 2016 9:26am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 828 |
16th Oct 2016 9:36am |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
[quote="Haylands"]Been loads talked about this recently but no "one place" to find all the info...
3rd Dec 2016 11:35am |
Hi,
3rd Dec 2016 11:39am |
That bit in Rave is a bit ambiguous, there is one temp sensor measuring the water at it's hottest part of the system, where it leaves the engine, and as Simon says it's not combined with the electric thermostat. There is another temp sender in the bottom hose outlet in the rad, which is the coldest part of the system. The internal temp gauge uses the top one, the bottom one can be read with diagnostic tools... Pete
3rd Dec 2016 12:21pm |
Thank you Pete, I've been watching the diagnostics in my last journey. The FFRR started getting warm so pulled over and put the heating in high with the ignition on (thanks to the new battery!) plugged in the diagnostics and the coolant temp was at 115 and the radiator temp at 5 deg.
3rd Dec 2016 12:44pm |
& Simon of course |
3rd Dec 2016 12:45pm |
If the rad never got higher than 7 deg then you have no water flow around the system, the other temp got cooler because the water would be stationary and as such the heat will have dissipated into the surrounding metal work. The temps inside the engine will have been very high.
3rd Dec 2016 4:04pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1523 |
40 deg C/104 deg F today and the water temp got up to 104 deg C/219 deg F a couple of times in traffic. Once moving, the temp dropped to 102 deg C/216 deg F.
13th Dec 2016 8:08am |
I did the mod and I couldn't believe the difference either, it was like all of the strain was being released from the engine and it just sounded and felt more relaxed, it was odd...
14th Dec 2016 11:44am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Really easy to do too, i didn't need to mod my housing for the bleed valve and didn't remove the fan or cowling either and as I used a 1/4 drive ratchet and extension it was really easy to undo and replace the 4 bolts and didn't need the cap head bolt.
14th Dec 2016 7:00pm |
MarkNL Member Since: 26 Jan 2014 Location: utrecht Posts: 44 |
http://www.onderdelenshop24.com/7016322-behr-thermot-tronik
2nd Jan 2017 3:53pm |
i ordered one of the vemo ones but didn't use it as i fitted the 80 degree mod, it is still in my garage in it's box.
2nd Jan 2017 4:48pm |
Lots of ways to get the temp lower, doesn't matter which one you use, this was the cheapest I could find... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
2nd Jan 2017 6:33pm |
