![]() | Home > Technical (L322) > L322 M62: Broke small vacuum line on air intake, now codes? |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
The codes have nothing to do with the vacuum line.
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
hi just had same problem changed thermostat to 80 deg and found broken small pipe leading to intake. repaired with pipe from fish tank . car is running better than ever as i have lpg she was throwing up eml when on lpg ond would cut out on hot restart had to keep foot on pedal . since pipe repair light is out and no stalling whatsoever i have been running like this for over a year and could not find problem . car is running great so i would def fix it . fish aint to happy though |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Mine came with the pipe spigot broken and stuck with messy mastic. Got a replacement complete intake hose from a car breakers for £15 earlier this year. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1560 ![]() ![]() |
I broke mine doing the thermostat mod. Fortunately there was enough left to refit the vacuum line. Ron B. VK2OTC
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I believe it goes to the PCV valve at the back of the engine, have a bit of a google but you definitely want it connected without leaks |
DoubleRL322 Member Since: 05 Jul 2016 Location: Orlando, FL Posts: 25 ![]() ![]() ![]() |
Thanks for all of the replies.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8557 ![]() ![]() ![]() |
No it's not...
Good to know Rik, thanks!
Haylands, I believe #6 is the thicker vacuum line coming off of the air intake hose.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
deleted |
Oh right, I'll shut up then... Pete
had a look under my bonnet and number 6 on the diagram above is the larger red vacuum pipe that connects to the vacuum hoses at the rear of the engine as shown and the small vacuum pipe goes to the back of the engine, around to the right and eventually disappears behind the coolant valve / auxiliary coolant pump or into the inner wing.
Jeez, you'd better finish the job! Rip off the wheel and wheelwell liner and follow that line! |
