Home > Maintenance & Mods (L322) > 2010-2012 key fobs
Page 3 of 7 <1234567>
supershuttle
Actually its better if you use a sharp knife - less chance of scratching:
Although the pic shows the knife in the middle you do the corners Very Happy
 Geoff
Post #398504 31st Jul 2016 8:50am
JWL
Where is the best place to go for blanks for the big keys? Is this a main dealer visit or is there somewhere online? I have 2 that I need to refurb as the rubber coating is start to peel.
thanks, James
Post #402069 26th Aug 2016 12:04pm
you might to have a look at 'daveos' thread in the group buy section.. ... - .- -.
Post #402071 26th Aug 2016 12:08pm
Vogue
Main dealer did mine for £8.11 last week - all in including new genuine casing and labour - no point messing around doing it yourself Very Happy 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #402144 26th Aug 2016 7:31pm
so i took a leap of faith and had a go at changing the key fob and to my surprise it works!!
before,
after,
the new fob cost £10 off ebay and unfortunately doesnt have the 'range rover' logo on it ..maybe the next one i purchase will have..
its fiddly to do but quite easy..i had to do a little fettling to get the pcb board to fit by just taking about 1mm off one 5mm long edge ..
the emergency key blade fits under the silver side bit.. ... - .- -.
Post #403852 7th Sep 2016 1:13pm
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Brilliant. I wil do mine now! Bow down Bow down
Post #403874 7th Sep 2016 2:36pm
JPHC
If only i could get my 08 key to look like that Big Cry
Looks good though Stan Thumbs Up Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #403878 7th Sep 2016 2:58pm
thanks chaps.. Thumbs Up
its got a good range to, whilst i was messing about transfering the fob insides (back bedroom) i kept pressing the open/close buttons to make they worked and i found out later from my neighbour that my FF (at the front of the house)was opening and closing Laughing ... - .- -.
Post #403881 7th Sep 2016 3:05pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
Thanks Stan - this is really interesting.
Do you have any sense of how much smaller and lighter the new key fob is than the original? Maybe a picture of old and new side by side would help, as well as approximate weights courtesy of kitchen scales?
Thanks
Steve Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #403886 7th Sep 2016 3:23pm
its about 2/3rds the size of the old fob and much lighter steve... ... - .- -.
Post #403893 7th Sep 2016 3:46pm
Stan - I've got an empty one on my desk with the Range Rover in the metal section - if you want it, PM me your address & I'll stick it in the post
I kept it from when I accidentally took mine swimming - the inner was knackered, but I keep the case just in case.....
Post #403895 7th Sep 2016 3:58pm
you are a star alistair, ill pm you now.. Wink ... - .- -.
Post #403898 7th Sep 2016 4:06pm
thanks to a very nice gentleman by the name of alistair i now have a more authentic looking key fob with the range rover logo on the silver bit..
although the chinese jobbys are ok i think a genuine LR fob would be more preferable due to the better quality materials used..
Post #404172 9th Sep 2016 3:14pm
steveball
Inspired by the success of Stan and others, I've also replaced my bulky 2010 key with the slimmer, lighter model. Only the cheapo eBay shell at £10, but looked carefully for one with the Range Rover lettering.
Entire job, from start to finish, no more than 15 minutes. Easy to remove the bottom from the old key following instructions here. A bit of sandpaper to remove a mm or two from one edge of the circuit board and it fits a treat. No tracks nearby so easy and safe to do.
Whilst the height and width are a bit smaller than the original key, the real advantage is that its about half the thickness and a little over half the weight. All in all a very worthwhile, easy and cheap job. Definitely going to do the same with the spare key so that I have a matching set.
Post #404901 15th Sep 2016 7:55pm
nice job steve.. Thumbs Up ... - .- -.
Post #404904 15th Sep 2016 8:06pm
