Home > Maintenance & Mods (L322) > FFRR Service
Page 1 of 3 123>
Realist
Wales
FFRR Service
Guys,
Just had our RR serviced my a friend and now the dashboard says the following:
STOP ! ENGINE OILPRESS
And the oil light keeps flashing?
Any ideas.
Thanks Range Rover quotes.....
The Luxury That�s More Than a Luxury.
Conquer the world, and look good doing it.
Built for the unexpected.
Over prepared, but never underdressed.
2007 Vogue SE TDV8 Epsom Green (old car).
2010 Discovery 3.0L GS Mk4 Black.
Post #389358 30th May 2016 2:31pm
insufficient oil in the engine me thinks......check the level and see if theres any in there..... ... - .- -.
Post #389360 30th May 2016 2:36pm
Realist
Wales
Should be I hope it's just been changed within the last 2 hrs.
Check now. Range Rover quotes.....
Post #389361 30th May 2016 2:39pm
mr_spock
He wouldn't be the first person to put new oil in with the drain plug on the bench Smile
Post #389362 30th May 2016 2:43pm
Realist
Wales
Just checked oil it's clean and on the full mark 😡
Error code comes up as LCM- LIGHT-CONTROL
0x53 Engine oil pressure fault. Range Rover quotes.....
Post #389364 30th May 2016 2:54pm
Realist
Wales
Is it safe to drive with the above message showing up. Range Rover quotes.....
Post #389367 30th May 2016 3:16pm
Realist
Wales
Took the car for a little drive and as soon as its driven the message disappears but as soon as you stop the message pops back up on the dash. Range Rover quotes.....
Post #389371 30th May 2016 3:42pm
Mikey
Replace the oil filter with an OEM one, and make sure it's fitted properly Shocked
Post #389372 30th May 2016 3:44pm
Realist
Wales
The filter is by Britparts all the cars filters was changed as a service pack.
Will check the oil filter to see if it's tight hence why no oil pressure building up. Range Rover quotes.....
Post #389377 30th May 2016 4:00pm
Lost for Words
Britpart? Get rid of it quickly! Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #389378 30th May 2016 4:04pm
Realist
Wales
Thought Britparts was ok? Range Rover quotes.....
Post #389380 30th May 2016 4:13pm
Lost for Words
They sell some decent stuff, but they are known as "$hitpart" for a reason and I would never use anything but an OEM oil filter. Thumbs Up Visiting from DISCO3.CO.UK
Post #389382 30th May 2016 4:18pm
mr_spock
Can you check the wiring to the oil pressure sensor? It's under the filter housing. As for the filter, there's a bypass valve if the filter gets blocked so even a Britpart one shouldn't cause the pressure sensor to trigger Smile
Post #389383 30th May 2016 4:24pm
Realist
Wales
Me not machanical minded so where is the sensor!
Also just checked the filter, it's tight as a ducks rear end. Range Rover quotes.....
Post #389385 30th May 2016 4:30pm
Mikey
Take the filter out, and replace it. Doesn't matter if it's tight
Post #389410 30th May 2016 6:06pm
Page 1 of 3 123>
