![]() | Home > Technical (L322) > Restricted Performance 4.4 tdV8. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2659 ![]() ![]() |
Does it have the updated secondary turbo drain fitted? If not then it may have been accumulating oil in the secondary inlet tract. A stuck change-over valve doesn't cause lots of smoke but will cause restricted performance. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
No, I don't think the turbo drain mod has been done.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
do you drive mostly under 2000 rpm?
You will know 1500 RPM is over 80mph in D, so I will have to start manually selecting 4th gear to see how it goes?
Don't need to run at 2500 all the time, but there is so much torque available that with a less than heavy foot its possible to never use the second turbo.
Thanks Nmj, I think you have explained the sequence , and put my mind at rest.
Are you able to post the whole LTB?
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1665 ![]() ![]() ![]() |
Forgive my ignorance but is a stuck change over valve as a result of the oil drain pipe issue or separate?
2 loosely-coupled problems that can occur if the secondary turbo is rarely used. The oil accumulates from the unused turbo and the valve's linkage can become sticky from dirt/grit getting into the joint to the extent that it doesn't move freely if not used frequently enough.
I have been told that the modified operating arm moves much more as the 2nd turbo fires up .
