Home > My Range Rover > New owner-to-be, Hertfordshire
mr_spock
Hi all,
Having just sold my 2003 Jag XJ, which is being collected tonight, I'd been thinking about an L322 as a replacement. I loved the Jag, but needed more load space, so the L322 seemed like a good option. I saw one which was a complete mess - damaged trim, wrong ride height, noisy suspension, broken lamps and more. Then went to see a local car which I just put a deposit on, and should collect in a few days when the owner has removed his private plate.
No pics yet, but what I know so far:
    2003 4.4 Vogue
    Black (is that Java Black?)
    LPG with a BRC system, seems to work well
    Factory entertainment with analogue TV and DSP
    Parchment or Ivory piped in black
    Heated steering wheel
    Parrot BT kit, seems disconnected though
Now, thanks to this great site which I've been using to help me learn, I'm pretty sure it needs this lot - I've put my budget prices for anyone to comment on, and for me to look back on when I'm proved wrong!
    A service - need to check, but oil and filters. I'll get my local specialist, Aylmer, to do this and check the whole thing over - budget £350
    LPG service - no record of it ever being done sadly. Local BRC place quoted £150 for full service with filters
    Exhaust blow, somewhere in the middle - split cat perhaps? Budget £50 and hope
    Wiper motor - it's a bit floppy at the top of its travel and there's no water flow, so budget to replace it £150
    Compressor - it was slow to come to off road height, and to recover from access mode, and the compressor is a bit noisy. Same as the Jag compressor, so I can rebuild or replace. I didn't check, but I expect its been relocated away from the LPG tank which may explain some of the noise. Budget £35 for Andy's kit
    Rear heated seats - no lights come on at all. Of course I'm hoping its a fuse...
Some cosmetics I'd like to improve:
    Drivers seat valance - not cracked, but come away from its mounting. I'm guessing tabs broken off? £85 if I have to replace but I bet I can fix it somehow!
    Driver's seat bolster a bit worn. Furniture clinic kit in the summer perhaps, I'll see how it cleans up.
    Left dash walnut trim has had a phone mount. This will annoy me unless I can re-use it. £50 from ebay
    LCD is missing pixels. This kit looks decent and I'm ok with electronics: http://www.diyspareparts.net/rover.html £40
    While the Foundry finish parts of the dash are good, the rear panel for the heated seat switches and the front fixed cup holder are going bad. I'll probably paint these for now
    Driver's side window switch panel has the rubber finish going. I may attempt to refinish or buy wood overlays. Same with the steering wheel spokes.
It also REALLY needs a clean, and the corners of the back bumper have taken some wear, so I may paint this at some point. And I'd like a reversing camera (my wife can't turn her head very well) and DTV (because, well, it's there).
I will update with pics when I get it!
And a big THANK YOU to everyone who contributed to the wiki and various threads to give me the confidence to buy this. The Jag was complex, this is more so! I'm no stranger to fixing cars though, having had a Porsche 928, and now also have a Series III awaiting work, and a 57 Plymouth in the final stages of restoration.
Cheers
Ian
Post #381282 8th Apr 2016 1:48pm
Welcome to the forum
Sounds like a decent list of jobs to keep you busy Thumbs Up
Post #381295 8th Apr 2016 5:36pm
Sounds like you need to live long and prosper!
Welcome Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #381296 8th Apr 2016 5:38pm
24valve
United Kingdom 2010 Range Rover Autobiography Black TDV8 Santorini Black
Sounds cool. V8 ace!
Pretty sure it'll be Java black same as our 2003 l322.
Regarding the foundry finish, our rear heated switch area was a right mess, and it's fairly easy to dismantle and spray with a can of jollop for a couple of quid. I managed to find a good, textured match from halfords, and I'll dig it out over the weekend and let you know what it was.
Drivers seat surrounds are about 130 quid on eBay..
Alymer have a good reputation and I've used them for parts supply in the past- I'd be interested in your experience of them carrying out any work, as I may need to use them soon to sort a knocking noise out. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #381323 8th Apr 2016 7:30pm
mr_spock
Thanks all. First task will be some major cleaning!
Martin at Aylmer spent maybe 20 minutes this morning talking me through servicing options. He does seem to know his stuff!
How can I tell the difference between Parchment and Ivory?
Post #381327 8th Apr 2016 7:49pm
miggit
Welcome Bud, Land Rover Indys.... there are 3 in your area Shocked Aylmers as you say, but there is also http://www.benington4x4centre.co.uk/ , I've not heard a bad word about them and there is also http://www.gandgautomotive.co.uk/ , who are top notch... in fact one or both worked for Aylmers in the past! I'd be inclined to get a quote from them all, Whistle you might get it cheaper Wink
You don't say which wiper(s) that are wobbly, and with no water.... the rear has a bad reputation for malfunctioning.. which includes the washer part.. but we have sorted a fix for that, under £5 Very Happy
Reversing camera is a doddle there is a good write up here http://www.fullfatrr.com/forum/topic24647.html Read it all cos I did it slightly different, and saved heaps in the process, more info here http://www.fullfatrr.com/forum/topic37019.html and there is a pin out diagram in this post http://www.fullfatrr.com/forum/topic36466.html
Drivers valance might just have come detached at the front... it has a very dodgy plastic clip arrangement that can ping off and it all goes Pete Tong.... However my seat has done this twice without braking Very Happy so all is not lost, yet Thumbs Up
And one last thing.... if you intend to do any work yourself, and it sounds like you do, get a Gap IID Tool, it is the next best thing to the Land Rover kit, at a fraction of the price.... It will allow you to change settings for keys, height, bulb monitoring etc. there ain't nothing like it... except the dealer, and they want paying for the privilege Shocked
Lastly if your stuck, ask, someone will know, and if your really lucky they'll reply too Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #381359 8th Apr 2016 10:58pm
mr_spock
Thanks for the advice! Aylmer is very convenient as I drive past every day on the school run, but I'll call the others too.
It's the rear wiper. I suspect the white fibre gear is knackered at the start of the travel, but the lack of water can be a bunch of things but I need to get in there to see.
I'd like am IID tool if budget permits!
Can't wait to get my hands on it!
Post #381393 9th Apr 2016 10:44am
johnboyairey
i have an lpg similar year car. i have been quoted about '£100 for an LPG service', maybe thats filters on top, and that will be with vat, say £150. and good for 2 years i was told.
my car has 165k on it, and that means, 100k on lpg setup. from history. drives perfect. i have changed the suspension pump, for new one. £300 as i changed the seal and didnt get a satified result. what happens, is the pump up time is calibrated, if it doesnt reach height within a certain time, it throws itself into a wobbler, and you might need to have it reset, which involves a diagnostic tool. these are perhaps the best investment, especially if you save on some other work, like some detailing, or bumper tidy-up. You might have not yet splashed out on.
keep an eye on coolant level, read up on the PCV (breather unit) hoses at back of engine... and soft heater hoses, again at back of engine. access by removing pollen filter unit.
i dont get any codes, using my lpg. but, expect perhaps something to do with O2 sensor, if you have an exhaust problem. get a free exhaust check, when at say kwikfit, and when he takes you underneath to show you, take a picture, and then post here, or find someone local that can weld it. Often the cats, crack at the welded joins, and can be repaired easily, by taking off the exhaust. the exhaust is one whole unit, (massive) and obviously expensive, yours should not have any clamp joins, but some do have clamped repairs, and these need looking at first. however, people sell exhausts, on Ebay, in sawn parts, to clamp onto yours etc. dont consider cheap new pattern/budget cats, as they dont last. but consider secondhand original ones, from say known milage wreck. these should last the lifetime of the car...
The drivers seat trim, is very common, and new one will look great, but one day you will jump out, and possibly crack the new one. i did. so now i have placed a couple of black head countersunk self tappers to hold it in place. at front and top near to leather etc screwed into the seat housing frame plastic.
i took all my chipped foundry grey parts off, and sprayed them black, and laquered them. was a big job though. especially the nav trims/surround. some parts are avilable to clip over tatty trim, in say black, or wood. or you can find secondhand wood. some colours not to everyones liking.
i find the usefulness of the car especially good. always got junk, or bulky stuff in the back.. -engines, rubble.
fridges. got some original roof bars on top too, for massive boards and timber.
look up on internet before you go on a long journey, where to find LPG to get you home. saves you hassle. you can also use a phone app. or POI's on your phone etc. i think i get about 230 miles before i start to wonder if i will run out. i keep petrol at 1/3 full.
ive noticed recently, a good few BP garages that were selling it, (london area) have stopped stocking it, so dont rely on old info, and arrive to find it not stocked. Shell seem to be good still.
Post #381398 9th Apr 2016 11:20am
mr_spock
Thanks for the tips! It's had two water pumps in the past, and there are no signs of leaks at the moment that I could see. I can see myself getting an IID tool just to set the access height as low as possible for my wife. LPG is a "nice to have", but having had a few large V8 vehicles I don't worry about MPG too much. My wife's diesel B-class Merc does 50+ MPG and that's used most often.
It's possible that the time for the air suspension to come to height was due to it sitting for a while and the tank being empty. We'll see.
I'll start a thread when I get it...
Post #381418 9th Apr 2016 1:23pm
johnboyairey
with the compressor issue, normally if the pump is running, and you open a door, it stops..... maybe, if you think its real low, and it starts pumping as you get it to start it, count to 60, and, perhaps try opening a door, and turn off ignition... maybe you will then reset the timer, and you can have another 'free minute' on the pump..
maybe, dont quote me on it though!
you will soon be loving the drive. at first you might forget the slight roll coming onto a roundabout, compared to the jag etc, but im sure you will soon be all 'range-rover-besotten', like us on this forum..
however, the beards, sandals, and camo' hats, stay with the land rover series' guys.
we are normal looking... Rolling Eyes
Post #381421 9th Apr 2016 1:46pm
mr_spock
The pump didn't time out, it just took longer than I expected to reach full height.
I also have a Series, but no camo gear, beard or sandals. Do I have to sell it now? Very Happy
Post #381423 9th Apr 2016 1:55pm
miggit
The rear wiper/washer gets blocked up in the shaft and the non-return valve which is a couple of inches before the wiper motor... if you pop the hose before the valve, PUT A BUCKET ON THE REAR SHELF, you can get a helper to operate the wash/wipe while you direct the flow in to the bucket..... BE WARNED IT DOES SEVERAL PULSES... so there is potential to soak the car while the wiper is moving Shocked My pal tested his without a bucket, by himself.... flooded the parcel shelf Embarassed Then you just work your way up the line until the blockage is clear... if you need to remove the wash jets, read the link below for motor repair as this gives details on how to get it all apart Thumbs Up
The seal on the wiper shaft can wear and cause it to leak... this will leave a rusty puddle on the inside on the trim panel that covers the motor. Info on repairs here http://www.fullfatrr.com/forum/topic9792.h...iper+motor Yesterday I couldn't spell Engineer... Today I are one!
Post #381491 9th Apr 2016 7:06pm
