![]() | Home > Maintenance & Mods (L322) > power steering fluid |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
i've just replaced my servotronic valve and need to top up the power steering fluid , so has anyone used anything other than the user manual recommended stc50519 fluid ...if so, any problems... ... - .- -.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
I can't help with your question scarey, but can I ask why you changed the valve and what was involved? |
my steering was getting heavy on slowing for corners and roundabouts cos the valve could not cope with the sudden speed change and after searching the web and talking to a LR mechanic it was diagnosed to be the valve..this valve regulates how light/heavy the steering is at what speed the RR is travelling at...
Not specific to PS fluid fella, but a past experience taught me to only ever use the correct specification of lubricant. Sure it costs a bit more but I look at it in terms of the uplift in cost.
Thanks for the info scarey.
thanks for the input chaps, its only a very small top up i need and i'm a bit reluctant to spend £17/18 for a big bottle of the stuff...but it does make sense..... ... - .- -.
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
i done quite a bit of research on this as i wanted to flush my power steering fluid, after a lot of reading it turns out that texaco 7045e as used in the transmission is also recommended for the steering or at least thats what it says on the texaco web site. |
@ arron
the things you get for xmas 'eh Tim.... |
