![]() | Home > Technical (L322) > TDV8 4.4 Engine Issue |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8744 ![]() ![]() ![]() |
possibly one of the intake tubes on top of the engine has split. apparently a reasonably common problem a bit like the turbo hoses on the 3.6. there is an updated part available to replace it with. Lift the cover and have a look, it just lifts up There is nothing that can't be fixed with a hammer😜😜
Robbo1 Member Since: 22 Jan 2016 Location: Coventry Posts: 4 ![]() ![]() ![]() |
Thanks for the quick response, will have a look in the morning. |
If not an intake pipe the 4.4 does suffer with an oil leak issue from a pipe on the rear of the EGR! Spreads engine oil all down the back of the engine/bell housing which can get on the exhaust and smoke! |
Thanks Craig, excuse my lack of knowledge but what is the EGR? |
Oh dear |
No problem, if it is the pipe on the EGR is it an easy fix? |
Not easy no. Involves stripping lots off the top of the engine to get to it... I would check the intake pipes first, then if not them? Put the car on a ramp and see if there is lots of oil over the back of the engine first... |
