![]() | Home > Technical (L322) > What should battery voltage be while running |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
i have got one mine shows 14.1 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
Should be around 14.4, they are not very accurate though.... Pete
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
My faulty battery showed 14v via the 753 hack and the new one shows as 14.5 so have to assume thats about right! |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
If you are using a lead calcium battery.......and all of us should be.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Agreed |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
The diagnostics screen voltage is far too inaccurate to be relied upon. ![]() FWIW, to truly check the alternator output, it actually takes a very good multimeter or even an oscilloscope. A normal multimeter is normally adequate though. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
The real time water temp gauge that I fitted also shows voltage, it's reading between 13.9 and 14 volts. As it's not connected directly to the battery, and its' accuracy is unchecked, I'm not overly worried by the readings that I'm getting.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Thanks everyone, its showing 13.7 on a short trip (5-6 miles) and not had the chance to test it over a longer journey (not sure if it will rise the more the battery gets charged?). The battery has ran flat a couple of times due to a faulty FSR so unsure if the battery suffered damaged from draining right down, or if the alternator isnt charging as well as it should. Its never not started (touch wood) recently, and I am thinking of fitting a new battery before the winter just to be sure. |
I have a good quality voltmeter permanently installed connected to the front fuseboard which generally indicates a running voltage of 14.1V to 14.2V. Charges the battery with no problems.
Thanks Nicedayforit, and you have no problems starting with it sat at 12.6v after a few days? I've not measured the voltage before starting her, but will see later today.
What is exactly? ![]()
Fron a charging perspective, yes, sort of. When it really matters though is for ECUs that can be extremely sensitive to voltage, and it becomes the difference between normal functioning and all hell breaking loose... Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
@mrblonde.
Lost for Words, temperature gauge syndrome........ the Range Rover temp gauge is controlled by the ecu and has no direct connection to the engine, so far mine has read "Normal" from 70 deg. C to 98.6 deg. C and not moved a hairs width.
