![]() | Home > Maintenance & Mods (L322) > Observations after Transmission service |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Just changed the 5hp24 filter and fluid with the help of my part time mechanic. He has a lift. Normally he wouldn't do a sealed for life transmission but I convinced him it was no big deal. On the way up I noticed a droning low rumble at speeds between 30 and 40 MPH. Sounded like driving over rumble strips on the road coming to a toll booth. Rumble rumble smooth, rumble rumble smooth. I was thinking a tire balance issue or something like that. We did the 5 liter and filter for now. I will do the other 5 liters in a few hundred miles. Fluid was very dark brown but not black. Not much on magnets and noting but oil in the pan. Drove home and felt how much smoother it shifted and I didn't think it shifted bad before. The rumble is gone. I feel much better now. Took about under 90 min. |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
What sort of milage did you have at time of service |
119k miles |
Good news then for you.
Pretty sure the manual says 20c for checking the fluid level.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
not hot weather, hot engine temp.
Erm, I was talking about fluid temp.
OK wasn't quite that precise. Will do with the next drain and fill next week. I made some assumptions from another writeup that it just needed to reach temp and nothing about it exceeding a temp range. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1002 ![]() ![]() |
Although it’s good to hear that your fluid refresh has stopped the torque converter lock-up clutch shudder I suspect this will only be temporary. I should start saving up to have your TC removed, re-manufactured and replaced if I were you (approx. £250 + 5 hours labour + filter + fluid). Worn LUC issues most commonly occur soon after 100k miles has been clocked up for the 5HP24 in the Range Rover. It will be interesting to see how long it takes for the cattle-grid noise to return.
Pretty reasonable to suspect that not changing the fluid.......because of the sealed for life BS leads to premature failure of such an illustrious trans as the ZF.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
You are correct |
RRPhil I've read your posts and value your input. I wish it was something different. How long does she have? 10 miles? 10k miles? Will this lead to other internal issues? Wouldn't it be best to plan on redoing the entire transmission while its out for the TC? Should I not drive it 300 miles to the beach this weekend? |
I didn’t get chance to replace mine for several thousand miles after the shuddering began and when I finally got round to it the friction plate still had material left on it. I just replaced the converter, the fluid and filter and all was fine after that. Therefore I would say there’s no immediate panic.
Bless you. We are packing as I post. My first long trip with the Beast. Theoretically if I don't feel that shudder/rumble return do I not need to worry until it does? |
