Home > Maintenance & Mods (L322) > Broken driver's seat valance trim
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
It was bound to happen, and yesterday was the day that the driver’s side seat valance trim broke off.
It was a bit shaky for a long time (probably 5 years) but never it always popped right back in, but not yesterday. It didn’t want to go back in.
So I took it off and will see if I can repair it, Gbp120,- for a replacement is a bit steep
I glued the trips back on; the one thing left to do is to fix the hole where the screw goes
Untitled by Chris, on Flickr
If somebody has a driver’s side seat valance spare and willing to sell, than PM me (needs to be the sand color one / parchment – year 2002)
Post #329984 29th May 2015 10:08pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Yes I had to replace mine a few months back, too few tabs left on it to glue! Had to get a new one, island4x4 were a little cheaper than the dealer. Good luck!
Post #329985 29th May 2015 10:30pm
mjdronfield
I replaced mine a couple of years ago. It started creaking when the screw hole bit bust. Some tabs broke when removing it.
This is where side steps really help though, as it doesn't get clobbered getting in and out.
Someone on here has had theirs covered in leather, so covered up cracks etc. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #330006 30th May 2015 6:38am
Did mine with vinyl then colour matched with trim paint, looks much better now...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #330024 30th May 2015 10:20am
Can anyone describe exactly how these trims come off, preferably without breaking anything.
One of mine needs a bit of care but I don't want to make it worse removing it.
Post #330036 30th May 2015 11:28am
Screw at the back, overcatch arrangement at the front, then pull it off towards the door, most of the catches will have broken off though... then unclip the switch pack and lumbar button... Pete
Post #330086 30th May 2015 7:54pm
Thanks Pete Thumbs Up
Might just have a go at removing it with a view to covering it.
Post #330097 30th May 2015 9:09pm
hex
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
Had the same issue with so making one out of steal ,if that goes OK I will make another out of alli when I get some pure argon for the tig welder .
I will post some pics tomorrow if anyone is interested
Post #330100 30th May 2015 9:27pm
It's fixed to flimsy plastic bits on the seat though... would need a redesign and better mounting... Pete
Post #330102 30th May 2015 9:34pm
Havank
The clips got fixed with contact adhesive the day before, however the fixing point at the rear, of the valance is the tricky part. I think that most people have an issue with this.
As you can see a lot of the material got broken off. So there is not much material to repair. Whilst working on this I found on the worktop a 5P coin; although to big with a bit of grinding on the grinding wheel it got a perfect round shape to fit in the hole.
Together with liquid steel this forms a perfect bonding and strong enough to make a new fixing
Last night I got the drill out and made a new hole through the 5p – hard material, and filed the back off, to a good flat surface
With this now fixed it was double the thickness, so the original bolt will no longer fit. A rummage through my screw and bolt pot and a new bolt was found. Ok not a torx screw, but thread is more important
Then a bit of fiddling to get it back on again. I found taking the seatbelt off made it a lot easier.
Doing this on a live car is stress. Working against the drain of the battery
Now this is out of the way, I can concentrate again on building my bike and tool shed
Post #330187 31st May 2015 11:19am
entered into the wiki chris.. Thumbs Up ... - .- -.
Post #330190 31st May 2015 11:29am
fullfatbob
England 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Brilliant...my seat valance both sides are on their last legs...
I just wanted to ask....which primer and trim paint did you use..as could not find a colour code for Sand (SUN) from Land Rover.
Thanks
Post #387828 19th May 2016 11:44am
Waynetab
United Kingdom 2004 Range Rover HSE 4.4 V8 Galway Green
Replaced my drivers side seat valance a few weeks ago. Only £80 ish from Dan@Duckworths
Post #387901 19th May 2016 6:53pm
May be a much easier job for removal and refitting by removing the seat from the car, only five bolts (inc. seatlbelt) and disconnect the power seat connector (maybe good to disconnect battery also). Then you can really see what is going on. .
Post #387920 19th May 2016 9:12pm
Thanks
Paint from here....
http://www.furnitureclinic.co.uk/Land_Rove...rettyPhoto Pete
Post #387939 19th May 2016 10:58pm
