Home > Wheels & Tyres > tyre size options on 22's
Page 1 of 3 123>
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Love them or hate them, I'll be needing to fit new tyres to my 22" wheels soon. At present they are 285/35 x 22
Are there any other options, as the ride is quite/very hard?
Just wondering what other tyre size/combination you guys use on 22's?
Post #326988 10th May 2015 8:48am
Anything taller is going to affect your speedo reading
Are you asking what will physically fit ?
L405 22's run 275/40/22 but are slightly taller Thumbs Up
Post #326993 10th May 2015 9:12am
I run Conti 275/40/22 L405 tyres on my 2012 322 and they are a vast improvement over 285/35/22’s sir both in comfort and appearance... Your size IMHO look too skinny! 405 size fills the arches better.. Pic bellow Thumbs Up
Post #327003 10th May 2015 10:26am
RiccartonRR
IMHO 285/35 R22 are just too thin and sports-car-esk!! Also, IIRC the Pirelli ones in this size are 109 load rated which makes the car push on a bit through the twistys. I'm running Hankook RH06 iin 305/40 R22 114V and in terms of appearance, grip (wet & dry) & noise I cannot fault them. They are also M+S rated Thumbs Up See pic below.
I know they haven't got the aggressive look of the LTZs but then that isn't always the look one is trying to achieve.
BTW - tried to tell my insurance company about the non-standard wheels and tyres but was told they weren't interested Shocked Apparently farmers seldom ever stick to "standard" sizes so they've given up worrying about it Laughing
Post #327040 10th May 2015 4:20pm
I welcome bit of additional rim protection with 305's too I would imagine.
The 275's on the L405 do look awfully close to the edge of the tyre - I'm not sure how long mine are going to last Confused
Post #327041 10th May 2015 4:23pm
Any issues with rubbing? Even over BIG bumps with a loaded car?
Post #327045 10th May 2015 5:08pm
RiccartonRR
Craig - I'd be lying if I said no Laughing
I've got 6mm spacers on the rear but I don't think they're needed so will come off this week when I service the brakes. I also "moulded" the tank filler tube lump in the rear liner with a heat gun before fitting them just to be sure.
There's no visible evidence but I'm sure axle articulation with full lock makes the tyres just and so touch the liner grills - but as I said, there is no visible evidence of this.
And to top it all, if, hypothetically, you were testing the nerve of an Audi TT owner who took exception to a FFRR overtaking him and went through a "bomb hole" well on the wrong side of the ton then perhaps they could touch the rear wheel arch Laughing Laughing Still, during this hypothetical situation the TT drivers nerve would fail long before my tyres would cause a problem Thumbs Up Thumbs Up
I guess the particular wheels they are fitted to will also make a difference (off-set, rim width etc).
Post #327056 10th May 2015 6:04pm
Thats what i was lead to beleave sir Thumbs Up
Many with 22’s lower them slightly which would compound the issue i guess Whistle
Post #327096 10th May 2015 11:27pm
rr driver
United Kingdom 2011 Range Rover Autobiography 5.0 V8 Santorini Black
I have 22 OF Tigers on mine with 285/35 x 22 ( was on when i got the car) as i haven't been able to get a reasonably priced set of 20" Style 11 wheels, i am planning to just upgrade the tyres in the nest few months. I will probably follow what Craig has 275/40/22 - i am thinking of either the Conti or Vred All weather. any suggestions, also am i correct in thinking that there are no other alterations to be made- just get they tyres on and balanced etc.
My objective is to get a smoother ride and better handling. 2011 5.0SC Santorini Black
2009 5.0SC Santorti Black - Been stolen.
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #327097 10th May 2015 11:50pm
cripboy
Scotland 2015 Range Rover Vogue SE SDV8 Corris Grey
Hi
sorry to jump on the thread, but have just purchased, and I am due to collect a 2015 Vogue SE with 22" wheels. Will the 302x22 LTZ fit the 22" wheel or is it to wide?
Keith
Post #327173 11th May 2015 1:32pm
Nobody on here has tried yet as far as I’m aware so, you could be the Guineapig sir Whistle Bow down Thumbs Up
Post #327175 11th May 2015 1:38pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
285/40/22 are perfect. I'm running them. Would not consider anything less.
Post #327182 11th May 2015 2:41pm
JCW
I have 4 x brand new 275 40 22 108Y Continental Cross Contact LX Sport (I believe the same as Craig mentions) tyres I bought recently but my plans have changed now, so if anyones interested, drop me a message.
Post #327213 11th May 2015 5:58pm
Just checked that size and they are unknown this side of the pond Confused
Post #327218 11th May 2015 6:32pm
horse86
^^ There were like 3 options here. Went with the Toyo Proxy STII's
Post #327228 11th May 2015 7:33pm
Page 1 of 3 123>
