Home > Maintenance & Mods (L322) > Applying RR lettering without template
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Thought i would do a quick write up on applying new lettering and the best way i found todo it if your not supplied with a template. Not rocket science but might help someone out at some point .
what you will need:
masking tape
dental floss
de greaser/panel wipe
rubber wheel drill attachment
magic marker
1. Firstly mask around the letters taking one strip below and one strip above getting as close to the letters as possible then mask off between each letter.
2. Remove all letters, safest and easiest way i find todo this is use dental floss
3.Removing the glue, the rubber wheel drill attachment is defiantly the easiest way to get the gum/glue off but it is quite tricky doing this without damaging the masking tape, i had to remove the tape between each letter in order to remove the gum but made some guideline markings with a magic marker so the tape could be re applied after.
4. Give the area a good clean up with de greaser making sure that all of the glue is gone then re apply tape using the guidelines.
5. Apply new lettering and remove tape and admire Thumbs Up I also removed the Vogue and LR badge, i know some people don't understand this but i personally prefer it, much cleaner looking. i have a thing about badges i don't like them and always remove them from my cars however i do like the main RR badge and would never remove that but thats a bit different to most model badges etc
 Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #325456 1st May 2015 11:28pm
Nice job Thumbs Up
Post #325461 1st May 2015 11:51pm
miggit
Embarassed Embarassed I think I might have got it wrong Embarassed Embarassed
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Yesterday I couldn't spell Engineer... Today I are one!
Post #325464 2nd May 2015 12:21am
supershuttle
Good tip with the floss, another method is to make a template (before removing them) with some old greetings card and some masking tape, I actually reused the old letters including "VOGUE" and the bar above the number plate, just sprayed them with some silver wheel paint and stuck 'em back on with double sided tape , obviously you can't have the hi chrome finish doing this - but no money changes hands Very Happy
Although I no longer have the car apparently they're still stuck firm and looking good and of course I still have the template Very Happy
I still think the "G" on the bonnet is a bit wonky though Rolling with laughter Geoff
Post #325470 2nd May 2015 6:47am
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
That's going to bug me now, I hadn't noticed Big Cry
I was wondering what colour you had used as I want to do something with the door handles and wasn't sure whether to match the body colour or if titanium or something would match the badges
Post #325501 2nd May 2015 9:34am
Definitely body colour Fish... Thumbs Up
Post #325505 2nd May 2015 9:48am
nice job Mark, i've put this in the wiki.. Thumbs Up ... - .- -.
Post #325512 2nd May 2015 10:31am
markcaughey
Cheers Stan Thumbs Up Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #325523 2nd May 2015 1:13pm
Never trust the so called template that the lettering sets come in, the first time I used one, I applied it and they were all wonky, much better to do as here and just apply yourself one by one, this is what I did with mine. Discovery 4 HSE
Post #325526 2nd May 2015 1:54pm
Mark,
Top job, I like how your wrote on the masking tape, in case you forgot how to spell "RANGE ROVER"
I stuck a rear number plate on once and was paranoid about getting it square, spent ages measuring and marking, lined it up and stuck it on.... stood back and started swearing...... doh... upside down !!! Big Cry
Not my finest hour..... Pete
Post #325528 2nd May 2015 2:08pm
supershuttle
Sorry about the "G" I just used Simoniz 5 wheel silver Geoff
Post #325536 2nd May 2015 2:40pm
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Are there any measurements for the rear lettering ? The badging on mine looks to have been changed and was rather wonky. I have lettering but no template.
Thanks
Post #516625 27th May 2019 1:03am
BMG
Any chance someone with a car at home with a tape measure can tell me the distance from the lower edge if the tailgate to the low edge of the lettering ?
The rest I can copy from the front badging.
Thanks
Post #516777 28th May 2019 3:04pm
Weegie
4.5 cm on mine. Ie. four and a half centimetres . Straight line so all that distance. John
GAP iiD BT-Sold
Post #516779 28th May 2019 3:39pm
Woofster
Canada
I recorded 1" (or about 25 mm) from the top of the grey plastic tailgate trim strip to the bottom of the letters. 2010 RR SC
2007 RR SC
Post #516788 28th May 2019 4:44pm
