![]() | Home > Technical (L322) > P0314-01 Fault Code and Live Test Values |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
Cylinder 2 is massively over fuelling, causing your misfire |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Cheers for that info, much appreciated. |
Anything over +2 is bad...
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Take two injectors out and swap them around... If the fault moves you know its an injector... If it stays its either wiring or mechanical (probably wiring loom related though! |
Many thanks for the replies and suggestions guys. |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi what was the outcome as I have the same issue and fault codes at the minute.
