![]() | Home > Technical (L322) > Brake Lights permanently on when parked - Update! |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
May well not be but they do do some nutty things if the battery is not quite there |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2589 ![]() ![]() ![]() |
Yeh Sandy, that's my guess however have had the battery drain many times over the years and never a light issue, as usual it never ceases to surprise me |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
Mine did that when I drowned it in Wales, was water somewhere, actually it was water everywhere!!!
Thanks Pete, thats why I mentioned the snow, sounds daft but it was parked facing uphill which it never is and had a few inches on it which must have gone somewhere!! Will do a recharge in the morning and see where I get |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Also could be the LCM which is a black box behind the kick panel (behind the bonnet pull) check for wet in there too sir |
Thanks Craig
