![]() | Home > Maintenance & Mods (L322) > Engine Oil Change |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 354 ![]() ![]() ![]() |
Hi
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
nice 'how to'...wiki'fied |
Christian W Member Since: 09 Jan 2020 Location: Kemper Posts: 2 ![]() ![]() ![]() |
Hi,
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I thought it was sucked out with pump and drained a small amount from the drain plug I do hope your way is better than I have been doing? |
The detailed description from Emirates A380 says:
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Is there much to using any flushing agent or cheaper oil after draining old oil to run through and clean some more gunk out prior to filling up with lovely new spec oil? I've seen a few vids on Tube of You that do this... |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1231 ![]() ![]() ![]() |
RRover - With reference to using 'flushing oil' have a read through this thread.In particular Treebor99's comment. I look after engines from truck sized, we call them little ones, |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Ran a high pressure centrifugal compressor for 20 years, think it had 3 full oil changes in that time, never flushed once.
Gotcha! Cheers! |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 293 ![]() ![]() ![]() |
Hello there, just wondered if this can be done with the wheels on the floor, save me dragging my jack out of the shed. Cheers. |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Hi Joolsb
Yeah, I ended up reading those threads and ordered the draper pump |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 118 ![]() ![]() |
Just to add a final steep, reset service indicator via the OBD |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Good places to order oil:
